 96 RMW Coolant Leak
j2rossit
PostSubject: 96 RMW Coolant Leak   Thu Aug 07, 2014 8:58 am
Hi all,
So I just picked up a 96 Roadmaster yesterday. It's been sitting for several years but runs great. The only problem that has come up is the hose that runs from the coolant reservoir to a T connection that splices into the heater core line leaks at pressure.
It looks like the T connection is integrated into that hose. Is there anybody that makes these assemblies anymore or is there a way of reusing the T connector and just replace the hose?
PostSubject: Re: 96 RMW Coolant Leak   Thu Aug 07, 2014 10:12 am
The Tee is more than likely cracked, happens to all of them. I don't think you can buy the whole assembly, you can buy the Tee from the dealer or make a brass one. Using a dremel you can cut the clamps off and reuse the hose.
j2rossit
PostSubject: Re: 96 RMW Coolant Leak   Thu Aug 07, 2014 11:04 am
I'll look into getting the tee from the dealer because I don't doubt that it should be replaced. There is no coolant leaking down from the tee so I doubt it currently is broken, but I'd rather not have to worry about it down the road.
j2rossit
PostSubject: Re: 96 RMW Coolant Leak   Thu Aug 07, 2014 1:04 pm
I went to the dealership and was able to get a kit that contained the tee, the hose for the resevoir as well as the two hoses that connect to the waterpump. Now I just have to decided if I want to go whole hog and do the waterpump and optispark and other hoses as well. I plan on keeping the car for a very long time and it would be nice to have a spare working optispark on the shelf.
PostSubject: Re: 96 RMW Coolant Leak   Mon Aug 11, 2014 11:39 pm
Mine cracked last year, and I bought the entire replacement hose from the dealer for about $120.00 or so. The replacement is actually 2 hoses, including the tee, and takes about 10 minutes to install. I opted for the entire hose instead of a repair kit because mine had disintegrated and I was worried some of the old hose would migrate into the radiator or heater core, get stuck and cause some serious headaches. I flushed the system, and replaced the upper and lower rad hoses at the same time, along with the serpentine belt. As for the opti, unless the water pump is leaking, according to many posts here, leave the opti spark alone. I got a spare tee, by the way, in a junk yard, and keep it in the hidden compartment under the rear most seat, just in case.
j2rossit
PostSubject: Re: 96 RMW Coolant Leak   Tue Aug 12, 2014 6:08 pm
Yeah, by kit, I'm meant the hose assembly that contained all you mentioned. The reason I'm interested in doing the opti is that this wagon is my daily driver and I've got no knowledge of how many of the 190k miles are on the current opti. My plan for this car is instead of buying a newer car for tons of money, I'd rather buy this car for $1.5k and spend the balance of the money on what it would take to get it in as reliable a condition as possible. Sure I'd be risking the insurance coverage but I'd rather drive a car I like.
96 RMW Coolant Leak
» What We Need Here Now Is A Rick Mercer Rant, Peter Mansbridge To Get A Leak On The Settlement And For Stephen Harper To Do The Right Thing By Us
» List of domains using Cloudflare DNS (potentially affected by the CloudBleed HTTPS traffic leak)
» Yugioh Arc-V News leak (V-Jump)
