 FS: Performance Parts. + Part out: 94 & 96 9C1. Headers, 91 Tails, Catback, V Spring
MrBuick
MrBuick
FS: Performance Parts. + Part out: 94 & 96 9C1. Headers, 91 Tails, Catback, V Spring Empty
PostSubject: FS: Performance Parts. + Part out: 94 & 96 9C1. Headers, 91 Tails, Catback, V Spring   FS: Performance Parts. + Part out: 94 & 96 9C1. Headers, 91 Tails, Catback, V Spring Icon_minitimeThu Mar 25, 2010 2:44 am
Pictures are listed next to the parts in my thread on another forum, seen here. They were messed up when I attached them here.
http://www.impalassforum.com/vBulletin/showthread.php?t=239783
Parting out my 94 & 96 Caprice 9c1's. I also have some tail lights & 9C1 hoses off a 91 Caprice. I have some TBI hats off of 4.9 Caddy's as well. They are white, with blue interiors. One of them, the front have was SEM dyed black. I also have some performance Parts from my other Roadmasters, and Caprices.
*Note: I had another thread going before this, but It was messy. I Had no way to make mention of my performance stuff to come, without starting a separate thread. Which as we know, is a big no go.
*Prices *If you don't like a price, PM me an offer. Worst I will do is say no.
Performance Parts. - Will be added as they are ready to go.
Items Sold, don't have, kept for myself, or were no good.
*Note: If you don't see a part listed, I might have it. I might just not have thought about it, or pulled it off yet. If I for sure don't have it, you will see it in this list.
Long Block
Transmission
Rearend
Rear Disc Brakes
Driveshaft
9C1 Rims
Caprice hub Caps
Radiator
Optispark
Water Pump
Exhaust Manifolds / cats
Stock Catback
SS Grille
Caprice Grille(chrome is so-so)
LTZ Emblem
Mirror, 96 drivers side
Mirror, 94 Pass side
Bumper covers(they are trashed)
Parts For Sale.
*Prices are SHIPPED, unless noted.*
Engine & Underhood
Air & Fuel
Intake Manifold - $75
Throttle Body(Stock, w/ Sensors) - $40
MAF sensor - $25
Fuel Rail(sans regulator) - $50 pic1 pic2
Fuel Pressure Regulator - $30 pic1
Fuel injectors(stock, set of Cool - $40 pic1 pic2 pic3
Fuel Pump(around 40psi, not overly loud.) - $50
Sending unit(top section metal) - $40
Sending unit(bottom section, plastic) $40
Gas Tank(PLUS SHIPPING) - $50
Fuel Lines are in decent shape. If you want one of them, all the way to the tank, I can remove it.
Engine Oil, or Trans Fluid (Contacts it)
Crank Position Sensor - $40
Timing Cover(96, no sensor) - $50
Valve Covers - $25 pic1 pic2
Oil Cooler, 9C1(will not split up, sans oil filter adapter) - $75
Oil Filter Adapter (for cooler, trade for "L99" one possible) - $35
Trans Cooler(+ lines from front to Radiator) - $40 pic1 pic2 pic3 pic4
Trans Cooler Lines(Radiator to trans, pair) - $40
Tailshaft housing(96 W/sensor) - $40
Cooling System (Contacts it)
Coolant Hoses, 9C1 Green(91 Caprice) - $100 pic1 pic2 pic3 pic4
Coolant Hoses, 9C1 Green(95/96) - $120 pic1 pic2 pic3 pic4
Coolant Tank(94 no cap) - $30
Coolant Tank(96 no cap) - $30
Knock Sensors(96) - $25 each
Brake & Steering
Power Steering pump - $45
9C1 Power Steering cooler - $50
Power Steering Line from pump to box - $20
Power Steering Reservoir - $30
Brake Booster - $50
Master Cylinder - $30
ABS Pump(94 only) - $75
Electrical & Other
Engine Harness(96, 9C1, 3 wires cut by starter) - $120
Engine Harness(94, Caprice Towpak Wagon) - $120
Alternator - $75 pic1 pic2 pic3 pic4
Balancer - $30
EGR Valve - $40 pic1 pic2
Accessory bracket - $65 pic1
Belt Tensionor - $20 pic1
Ignition Coil(94/95, no ICM) - $30
Ignition Coil(96, no ICM) - $30 pic1 pic2 pic3
Misc Sensor or Solenoid - $10
Washer Tank - $25
Washer Pump - $10
Wiper Motor - $30 pic1 pic2
Evap setup(94, canister, lines, solenoid) - $30
Evap setup(96, canister, lines, solenoid) - $30
Radiator Tie Down - $40 pic1 pic2
Suspension & Under Car
Springs, Front 9C1(pair) - $75
Springs, Rear 9C1(pair) - $65
Sway bar, Front 9C1 - $75
Sway bar, Rear 9C1 - $75
ZQ8 Bump Stop - SOLD
Bump Stops(Stock each) - $5
Gas Tank, Fuel pump, etc - Check Air/Fuel above.
Heat Shields(pair) - $25
MrBuick
MrBuick
PostSubject: Re: FS: Performance Parts. + Part out: 94 & 96 9C1. Headers, 91 Tails, Catback, V Spring   FS: Performance Parts. + Part out: 94 & 96 9C1. Headers, 91 Tails, Catback, V Spring Icon_minitimeThu Mar 25, 2010 2:46 am
Exterior
91/92 Tail Lights(each) - $75 pic1 pic2 pic3
91/92 Tail Lights(pair) - $125
Bumper, Inner Front(Plus Shipping) - $50
Bumper, Inner Rear(Plus Shipping) - $50
Bumper shock, Rear(each) - $40
Bumper shock, Front Driver(each) - $40
Bumper shock, Front Pass(each) - $40
Bumper Chrome strip, front - $30
Bumper chrome strip, rear - $30
Core Support(Plus Shipping) - $50
Hood Latch Assembly(bottom side) - $50 pic1 pic2 pic3
Trunk Latch(lid side) - $30
Trunk Popper, electric - $25
Caprice Hood ornament - $30
Trunk Chevy emblem - $35
Mirror, Drivers (94, I forget if it's power) - $30
Mirror, Pass (96, power, painted black - $50
Tail light, Driver(black trim) - $60 pic1
Tail light, Pass(black trim) - $60 pic1
Tail light Driver(chrome trim) - $50
Tail light, Pass(chrome trim) - $50
Headlight, Driver - $35 pic1 pic2
Headlight, Pass - $35 pic1 pic2
Corner light, Driver - $20 pic1
Corner light, Pass - $20 pic1
Interior
Headlight Switch - $45 pic1 pic2
Heat & A/C Control - $40 pic1 pic2
Speed-O Cluster -$100
Speed-O Bezel - $50 pic1 pic2 pic3
Ash Tray - $40
Steering Wheel - $50
Air Bag(Driver) - $30
Air Bag(Pass) - $40
Will be adding more, and adding more pictures. Took longer than I thought it
MrBuick
MrBuick
PostSubject: Re: FS: Performance Parts. + Part out: 94 & 96 9C1. Headers, 91 Tails, Catback, V Spring   FS: Performance Parts. + Part out: 94 & 96 9C1. Headers, 91 Tails, Catback, V Spring Icon_minitimeThu Mar 25, 2010 2:48 am
» LOTS of parts F/S: T56 conv, C5 wheels, headers, heads, cam, CA's, stock parts...check it out!
» WF09 Parts Wanted/Offered/need brought to/from the Fest
» OCC tails FS over on ISSF
» SW Michigan: 94 Roadmaster Wagon part out. Lots of other sedan parts as well.
» FS: Tons of Aftermarket Parts, & Part Outs. Caprice, Roadmaster, Wagon and Fleetwood
GM Longroof Forum :: The Longroof Marketplace :: Parts For Sale-
