 95 Caprice - Oil Change Issues
rick-ii
95 Caprice - Oil Change Issues Empty
PostSubject: 95 Caprice - Oil Change Issues   95 Caprice - Oil Change Issues Icon_minitimeMon Sep 01, 2014 5:32 pm
Ok - changed the oil today in my 95 Caprice Wagon - then, oil dipstick began rubbing crankshaft - ever heard of this? Wrong dipstick maybe?
Thanks
Rick
PostSubject: Re: 95 Caprice - Oil Change Issues   95 Caprice - Oil Change Issues Icon_minitimeMon Sep 01, 2014 5:43 pm
So,. the dip stick was in the motor and the crank was not hitting,.
You changed the oil,.
NOW the crank hits the dipstick,..
sounds like PFM to me,.
what changed,.?
rick-ii
PostSubject: Re: 95 Caprice - Oil Change Issues   95 Caprice - Oil Change Issues Icon_minitimeMon Sep 01, 2014 5:47 pm
Correct.  PFM?
scoffman
scoffman
PostSubject: Re: 95 Caprice - Oil Change Issues   95 Caprice - Oil Change Issues Icon_minitimeTue Sep 02, 2014 5:23 pm
Pure F___ing Magic Wink
Never heard of an oil dipstick hitting the crankshaft. What's it doing popping up and down in the tube?
scoffman
scoffman
PostSubject: Re: 95 Caprice - Oil Change Issues   95 Caprice - Oil Change Issues Icon_minitimeTue Sep 02, 2014 5:28 pm
Do these engines have a lower dipstick tube? If so yours might be missing.
rick-ii
PostSubject: Re: 95 Caprice - Oil Change Issues   95 Caprice - Oil Change Issues Icon_minitimeTue Sep 02, 2014 5:55 pm
Yep, jumped all around and ticking -
PostSubject: Re: 95 Caprice - Oil Change Issues   95 Caprice - Oil Change Issues Icon_minitimeWed Sep 03, 2014 7:32 am
Weird, maybe the end is bent in a weird way? Try rotating it 180 degrees and see if it still happens.
scoffman
scoffman
PostSubject: Re: 95 Caprice - Oil Change Issues   95 Caprice - Oil Change Issues Icon_minitimeThu Sep 04, 2014 3:26 pm
I think you might be missing the lower dip stick tube. was the engine ever reworked? I've read tell that shops remove them and never put them back when rebuilding the lower end. It appears that you can insert it from outside of the engine so you could get a replacement.
» Change rank text to bold
» Change the color of the words.
» How do i change the cursor?
» Change Domain Name
» How to change the tab name of your site?
