 anyone have a variable-effort power steering solenoid/pintle assembly?
PostSubject: anyone have a variable-effort power steering solenoid/pintle assembly?   Wed Oct 08, 2014 2:43 am
The connector on mine snapped off. It doesn't look like you can get this separately anywhere, so if someone has one or can point me to one, I'd appreciate it.
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Wed Oct 08, 2014 6:20 pm
"If you would just stop fixing things,. things wouldn't break",..
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Wed Oct 08, 2014 10:51 pm
Nick, sometimes you're just way too clairvoyant. Sounds like I should update my sig.
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Thu Oct 09, 2014 6:39 pm
send me a pic of what you want,.. i have a 96 parts car,..
i'll mail it to you,.
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Thu Oct 09, 2014 9:57 pm
Are you referring to the steering column position sensor on the end of the columnĀ in the engine bay?
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Fri Oct 10, 2014 3:01 am
No, the solenoid that is on the back of the power steering pump. I'll try and get a pic for you guys to show you what I mean.
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Fri Oct 10, 2014 7:45 am
There are 2 Fleetwoods in the local yard, they should both have one.
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Fri Oct 10, 2014 12:49 pm
Thanks Fred, I totally spaced on the Fleetwood as a good source for that part. None of the local yards have any near me, so if you do happen to find one near you, that would be great. I'm also investigating getting Cardone to send me one, I just got a pump which was supposed to have it installed and it wasn't.
The thing is held on with a dammit clip... sorry, an external ring clip... and a threaded shaft with a splined head. I'm not sure what tool is supposed to be used to undo it.
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Fri Oct 10, 2014 9:35 pm
Hold the Bus,..
why are you changing the power steeing pump??
If the steering is suddenly losing pressure and hard steering for a few seconds,. its a common LT1 problem, The water pump starts dripping from the weep hole on the bottom side of the pump,. it coats the belt with coolant,. belt slips, it dries off due to friction,. belt grabs again,..steering comes back,.
PostSubject: Re: anyone have a variable-effort power steering solenoid/pintle assembly?   Sat Oct 11, 2014 1:30 am
Nick, it was the only way I could find to get the solenoid, except that it didn't come with it like it was supposed to. Regardless, thanks for that tip, that's good to know!
» Wanted: Webley Mk. VI & Inglis Hi-Power Pistol... DEWAT/Deactivated
» Browning Hi Power Holster
» Canadian Hi Power..... airsoft
» NHS - The McCanns Abuse of Power
