 washer reservoir and overflow tanks
papa
washer reservoir and overflow tanks Empty
PostSubject: washer reservoir and overflow tanks   washer reservoir and overflow tanks Icon_minitimeFri Dec 19, 2014 6:40 am
What works good to clean the plastic containers? My Caprice is the first vehicle that I've had with these parts. I usually drive 40s and 50s cars and trucks. I've heard some things that work, but don't remember what. Bleach, vinegar ? What have you guys and gals used? Thanks.
PostSubject: Re: washer reservoir and overflow tanks   washer reservoir and overflow tanks Icon_minitimeFri Dec 19, 2014 8:18 am
I would start with a good detergent. If that does not work, maybe the vinegar. I would be hesitant to use bleach, because it just makes the dirt look like it is not dirt. A bottle brush to agitate the mix might help. Be careful if you have an LT1 car, because the level sensor is in the overflow tank, and could be damaged by some cleaners. The washer tank sensors can be removed.
Wagoninabox
Wagoninabox
PostSubject: Re: washer reservoir and overflow tanks   washer reservoir and overflow tanks Icon_minitimeSat Dec 20, 2014 12:14 am
I would think some CLR. Be sure that everything is fully flushed out with plenty of clean water!
PostSubject: Re: washer reservoir and overflow tanks   washer reservoir and overflow tanks Icon_minitimeThu Dec 25, 2014 8:19 pm
Speaking specifically about the coolant bottle: It depends on what's in there. I've tried a few different things- vinegar, CLR, probably some others without much luck. How bad is it? The one I got with the car was totally caked with brown sludge. I ended up just replacing it for one that had far less sludge. I cut the original one open to see what's going on inside.
The chambers are connected by very small passages, so even if you dislodge big chunks they may be nearly impossible to get them out. I spent a couple of hours with the hose filling and shaking and dumping until I got a lot (but not all) of the crud out.
» 2-hose coolant resevoir (overflow) bottles
» Power steering reservoir hose
» filthy coolant reservoir tank
» Are good used tanks available?
» More polished over flow tanks
