| 77 cadillac going from 223 to 308 gears? | |
jjs88
Posts : 15 Join date : 2014-05-04
| Subject: 77 cadillac going from 223 to 308 gears? Sun Jan 11, 2015 10:44 am | |
| going from 223 to 308 gears is that a big change in performance? my caddy has a 472 with a th400. im doing a similar project to a caprice making it 308 to. but my Cadillac im wondering about cause im changing out its rearend cause of no aftermarket stuff was made for caddy rearends from that area. | |
| Subject: Re: 77 cadillac going from 223 to 308 gears? Sun Jan 11, 2015 1:52 pm | |
| Don't do it. The rear end in your 77 is an ultra strong 8.75 12 bolt, and will give you decent mileage without overdrive. With 3.08s, you will really need to swap in an OD trans. That big Caddy 425 is designed to make lots of torque at low RPMs. Come on over to the Cadillac Forums for lots more info: http://www.cadillacforums.com/forums/rwd-19xx-1984-deville-fleetwood-1985/BTW, your 77 has a 425, unless you swapped in a 472. | |
jjs88
| Subject: Re: 77 cadillac going from 223 to 308 gears? Sun Jan 11, 2015 5:03 pm | |
| i have a 472 in it now, the 308 rearend i have i thought would wake it up a bit. | |
| Subject: Re: 77 cadillac going from 223 to 308 gears? Sun Jan 11, 2015 6:55 pm | |
| What year 472? Any mods? Cam? Which heads? Rockers? Intake? This will help me suggest a rear gear.
You can actually get gears for the Cad rear. Up to 3.42s (came in 81 V6 cars). Posi, too. Rare, but they're out there. I have the same rear in my 81. | |
jjs88
| Subject: Re: 77 cadillac going from 223 to 308 gears? Sun Jan 11, 2015 8:00 pm | |
| its a stock 1971 472ci out of a sedan deville dropped in a 77 fleetwood and i have "demo headers" put on it just for looks. there 4 in a row pattern, thats mainly it. the engine alone is strong but im not an expert on gear ratios. putting in a posi 308 gear set i would imagine the car will throw more power to the road and take off faster with that? | |
| Subject: Re: 77 cadillac going from 223 to 308 gears? Mon Jan 12, 2015 1:47 am | |
| - jjs88 wrote:
- its a stock 1971 472ci out of a sedan deville dropped in a 77 fleetwood and i have "demo headers" put on it just for looks. there 4 in a row pattern, thats mainly it. the engine alone is strong but im not an expert on gear ratios. putting in a posi 308 gear set i would imagine the car will throw more power to the road and take off faster with that?
Power to the road won't change,. but it will accelerate better,. | |
| Subject: Re: 77 cadillac going from 223 to 308 gears? Mon Jan 12, 2015 8:31 am | |
another thing to think about as mentioned is engine speed. with those gears and no overdrive you are going to be running pretty high RPM at highway speeds. (high for a 472 anyway) | |
drmenard
Posts : 3 Join date : 2015-01-16
| Subject: Re: 77 cadillac going from 223 to 308 gears? Fri Jan 16, 2015 9:47 pm | |
| What will make a big difference in performance without lowering your rear gears is a switch pitch transmission. With a variable pitch torque convertor you get the best of both worlds.. The V/P TH400 was only made in 1965,66 and 67 but many th400 transmissions up to about 75 can be converted to switch pitch, also called variable pitch.. Do some research.. | |
| Subject: Re: 77 cadillac going from 223 to 308 gears? Sun Jan 18, 2015 2:41 pm | |
| - drmenard wrote:
- What will make a big difference in performance without lowering your rear gears is a switch pitch transmission. With a variable pitch torque convertor you get the best of both worlds.. The V/P TH400 was only made in 1965,66 and 67 but many th400 transmissions up to about 75 can be converted to switch pitch, also called variable pitch.. Do some research..
How would he run the speedometer,.? | |
drmenard
| Subject: Re: 77 cadillac going from 223 to 308 gears? Sun Jan 18, 2015 4:39 pm | |
| The tail of the transmission is the same. So what ever tail he has on the transmission now he could use on a switch pitch. All the cases on the early transmissions were the same and can be used. If not drilled for a switch pitch it can be drilled easy, its only one hole. But somewhere in the 70's they took out metal of the cases and can't be used.. around 76-77 I'm guessing.. These transmission came in Olds, Buicks and Cadillacs... Not Pontiac's that's 65 to 67... The used them in 64 but not in the TH400. In 64 they were in the ST300.. Not sure about other years in the ST300... At 105 years you should remember these.. | |
| Subject: Re: 77 cadillac going from 223 to 308 gears? Mon Jan 19, 2015 12:56 am | |
| the out put shaft of a switch pitch has no provisions for a speedo gear btdt,. i used to build short shaft switch pitch trans for my 442, | |
drmenard
| Subject: Re: 77 cadillac going from 223 to 308 gears? Mon Jan 19, 2015 12:47 pm | |
| This is true that Olds did not drive the speedometer off the transmission, it was off the front wheel. But Buick and Cadillac did have a speedometer drive on the tail shaft.. All those parts can be swapped around.. When your building a strong th400 it is best to use the earlier year parts. The aluminum pistons in forward and direct drums. Use sprags and not roller clutches . There are many different mods that can be done to make them preform well. | |
| Subject: Re: 77 cadillac going from 223 to 308 gears? | |
