 Will wheel adapters work?
5 posters
welkiemike
Will wheel adapters work? Empty
PostSubject: Will wheel adapters work?   Will wheel adapters work? Icon_minitimeWed Apr 08, 2015 1:03 am
I'm fairly new and this may have been covered, but I have
a question.
I found a nice set of chrome wheels with baby moon hub
caps and like new tires at a great price. The only problem is
that they are the older 5x4.75 bolt pattern. I've located
wheel adapters to fit the 5x5 pattern on my Roadmaster
wagon . Will they work on my Roady?
Thanks;
welkiemike
PostSubject: Re: Will wheel adapters work?   Will wheel adapters work? Icon_minitimeWed Apr 08, 2015 1:23 am
I should also mention that these are off a 1965
Impala.
PostSubject: Re: Will wheel adapters work?   Will wheel adapters work? Icon_minitimeWed Apr 08, 2015 7:34 am
Hi Mike
Don't have an answer for you, but someone will. Stock wheels for a 65 Chevy would be 14".
Ever run into the Statler Brothers in Staunton?
PostSubject: Re: Will wheel adapters work?   Will wheel adapters work? Icon_minitimeWed Apr 08, 2015 8:34 am
The concern is the offset. You need to check the offset of the wheels you are considering, and compare it with the offset, and thickness of the adapter. A half inch difference to the outside is probably acceptable. Do the wheels fit over the front brake calipers? The fronts may interfere with the top of the wheel opening as well. If the fronts are much farther out, they will put a lot more stress on the steering components, especially the tie rods.
welkiemike
PostSubject: Re: Will wheel adapters work?   Will wheel adapters work? Icon_minitimeWed Apr 08, 2015 11:30 am
I've run into one of the Staler Bros. at the grocery store. They're all retired now and no longer record.Anyway,I'll have to check the offset. Also these are 15" wheels.
Thanks;
The Norm
The Norm
PostSubject: Re: Will wheel adapters work?   Will wheel adapters work? Icon_minitimeFri Apr 10, 2015 10:30 pm
When you figure out your offset/back space check out http://www.rimsntires.com/specspro.jsp. It helped me when I was considering camaro wheels with the 5x4.75 pattern. Good luck.
The Stickman
The Stickman
PostSubject: Re: Will wheel adapters work?   Will wheel adapters work? Icon_minitimeMon Apr 13, 2015 6:19 pm
I agree with the others. I see no problems in using adapters as a general practice. But you have to do your homework and take lots of measurements. Use the site The Norm posted as it is a big help. See it doesn't just matter if the adapter works for the bolt pattern but also if the wheel is in the right position inside the wheel well.
» Hub adapters
» Will these wheels work?
» Wire wheel covers and wheel well trim For Sale!
» Bye-Bye air bag steering wheel! Hello Leather Olds wheel!
» Starter wheel/ Fly wheel 96 LTI NOS
GM Longroof Forum :: Longroof Tech :: Wheel & Tire section-
