| Fuel level | |
+5rjathon Andebe silverfox103 Fred Kiehl mrmajjikk 9 posters |
mrmajjikk
Posts : 2 Join date : 2010-12-10
| Subject: Fuel level Thu May 21, 2015 8:02 pm | |
| Hi guys, I am new to the forum but I have a question I have a 1995 BRMW all stock, only thing that has been done is the fuel pump and sender was replaced. The problem is that when I put about 10.5 gallons of fuel in it it shows that it is full. But if I am not mistaken, that car has a 21.9 gallon tank. When it is empty (which is not very often), the gas light comes on so I have no clue what the problem is..... Thanks for you input | |
| Subject: Re: Fuel level Fri May 22, 2015 7:56 am | |
| This is the GM standard readout of your gas gauge. Everybody complains about it. There are ways to improve the readout, but it is easier to get used to it, and compensate mentally than to fix it. Fixing it requires modifying the potentiometer on the sending unit. That means dropping your tank. The instructions are either on this forum, or on impalassforum.com. | |
| Subject: Re: Fuel level Fri May 22, 2015 9:36 am | |
| - mrmajjikk wrote:
- only thing that has been done is the fuel pump and sender was replaced.
The problem is that when I put about 10.5 gallons of fuel in it it shows that it is full. But if I am not mistaken, that car has a 21.9 gallon tank. When it is empty (which is not very often), the gas light comes on so I have no clue what the problem is..... Thanks for you input If you didn't have this problem before the new fuel pump and sending unit, I would say something got bent. Tom | |
mrmajjikk
| Subject: Re: Fuel level Fri May 22, 2015 11:28 am | |
| Actually, when I first purchased the car that was the problem. I replaced the pump and the sending unit... | |
| Subject: Re: Fuel level Fri May 22, 2015 12:12 pm | |
| For what its worth Ive never got more than 18 gallons in the tank,and Ive run it completely dry! | |
rjathon
Posts : 269 Join date : 2014-10-28 Location : Sun City Center, FL
| Subject: Re: Fuel level Fri May 22, 2015 5:38 pm | |
| When I fill my RMS the gauge goes far to the right of full. When it reads 3/4 it is down to half a tank. When it reads 1/4 it actually has about 1/4. When the little yellow light goes on I have about 50 miles left. Once I learned its foibles there was nothing to be gained by fixing it as it is consistent.
I suggest filling it full from various positions of the gauge and memorizing the critical points. | |
just me
Posts : 162 Join date : 2014-10-09 Location : Riverside, CA
| Subject: Re: Fuel level Fri May 22, 2015 7:45 pm | |
| GM learned a lesson with the first digital fuel guage it put in Cadillacs. They made it accurate from Full to Empty and dealers got bombarded by complaints about gas mileage sucking because the guage would drop pretty fast from full. People used to the old guages staying above 3/4 for most of the first actual 1/2 a tank thought the cars were total gas hogs, same type of person who NEVER actually figures out their true mileage. GM soon changed the digital guages to stay nearer to full for a lot longer to mimic the old analog guages and the complaints stopped. | |
CapriceCarl
Posts : 9 Join date : 2015-02-24
| Subject: Re: Fuel level Sat May 30, 2015 4:31 pm | |
| - just me wrote:
- GM learned a lesson with the first digital fuel guage it put in Cadillacs. They made it accurate from Full to Empty and dealers got bombarded by complaints about gas mileage sucking because the guage would drop pretty fast from full. People used to the old guages staying above 3/4 for most of the first actual 1/2 a tank thought the cars were total gas hogs, same type of person who NEVER actually figures out their true mileage. GM soon changed the digital guages to stay nearer to full for a lot longer to mimic the old analog guages and the complaints stopped.
Is this accurate for everyone? When the light comes on you've got about 50 miles left? That seems excessive. Normally when my light comes on I'm at the "E" already! | |
| Subject: Re: Fuel level Sat May 30, 2015 4:54 pm | |
| - Andebe wrote:
- For what its worth Ive never got more than 18 gallons in the tank,and Ive run it completely dry!
MORON! Just kidding,only ran mine low enough to set off the low fuel alert maybe 3 time and it took around 21 gals to fill it back up and I don't keep filling after the pump cuts itself off.My gauge reads the same way too! |
| Subject: Re: Fuel level Sun May 31, 2015 1:15 pm | |
| Since I replaced the tank straps, the guage never goes to completely full anymore. Stays under it and to get to the "normal" 400mi before filling her up again (the car that is) i drive till i'm way in the orange low fuel (i don't think the 93 Cappie has a warning light) Fuel consumption has not changed. | |
| Subject: Re: Fuel level Sun May 31, 2015 2:32 pm | |
| The Caprice should have a fuel warning light, and a chime warning as well. Depending on the low end of the resistance scale of the level sender, it may not trigger the chime or light. | |
| Subject: Re: Fuel level Mon Jun 01, 2015 12:20 pm | |
| Well the risk is running it dry. But i'll have a look, the light must come on as you turn the key? (as all of the dash lights) | |
| Subject: Re: Fuel level Mon Jun 01, 2015 7:43 pm | |
| Check to see if you have the multi function chime module. The FSM has the troubleshooting chart. If you do not have the FSM, the 92 is identical, and there is one on ebay cheap. | |
steel-and-fire
Posts : 240 Join date : 2013-07-08 Age : 35 Location : Staten Island, NY
| Subject: Re: Fuel level Tue Jun 02, 2015 9:38 am | |
| I'm kinda glad this got brought up. After my 89 Buick Electra got towed and had its 2nd transmission fiasco, the gas gauge became a bit wonky.
On a full tank, the gauge would go past Full and stay there for a while (150-200 highway miles). It rarely reached Empty. Now, it barely touches the full mark and goes to Empty much quicker. I have about half a tank left at empty now, so I've been using my tripometer for gas trips.
Kinda annoying since it was so good beforehand. Was curious how to go about fixing it. | |
| Subject: Re: Fuel level Tue Jun 02, 2015 9:48 am | |
| The gauge reads resistance from the sender. The higher the resistance, the more full the gas tank is. If you have a weak short in the wire, it could make a parallel path to ground, and make the gauge think the sender is at a lower resistance. Other than that, the sender may have the coil stretched toward the bottom, and it never sees the one end of the potentiometer. | |
rjathon
| Subject: Re: Fuel level Tue Jun 02, 2015 9:54 am | |
| I think you are all mistaken. My tank has a little Leprechaun in it. He floats around in there and sends the signal. Now that we have ethanol in the fuel he is drunk most of the time and can't be trusted to stay on the job. Yet another unintended consequence of political folly... | |
| Subject: Re: Fuel level Tue Jun 02, 2015 11:00 pm | |
| - rjathon wrote:
- I think you are all mistaken. My tank has a little Leprechaun in it. He floats around in there and sends the signal. Now that we have ethanol in the fuel he is drunk most of the time and can't be trusted to stay on the job. Yet another unintended consequence of political folly...
Your leprechaun must be a democrat! |
| Subject: Re: Fuel level | |
| Fuel level | |
