 Which Water Pump
rjathon
rjathon
Which Water Pump Empty
PostSubject: Which Water Pump   Which Water Pump Icon_minitimeSun Jun 21, 2015 4:53 pm
Rock Auto has two different AC Delco water pumps:
#252700 which costs $89
#251555 which costs $182
Which one is recommended?
Thanks,
PostSubject: Re: Which Water Pump   Which Water Pump Icon_minitimeSun Jun 21, 2015 7:12 pm
Did you click info? Is one rebuilt, one new? Is one the incorrect F or Y body one?
PostSubject: Re: Which Water Pump   Which Water Pump Icon_minitimeSun Jun 21, 2015 7:59 pm
Gates pump is popular on Rockauto, and I would personally use one, Gates makes quality parts and is, in many applications, an OEM supplier for GM and many other makes.
rjathon
rjathon
PostSubject: Re: Which Water Pump   Which Water Pump Icon_minitimeSat Jun 27, 2015 9:26 am
Thanks, I bought the Gates on Rock Auto.
PostSubject: Re: Which Water Pump   Which Water Pump Icon_minitimeSat Jun 27, 2015 6:54 pm
I went through this before, between 2 repairs I ended up buying one of each. The expensive one has a stamped steel impeller, the cheap one has a cast iron impeller. My guess is the iron would rust out quicker than a steel one.
rjathon
rjathon
PostSubject: Re: Which Water Pump   Which Water Pump Icon_minitimeSat Jun 27, 2015 9:18 pm
Both the Gates and the AC Delco have stamped steel impellers.
PostSubject: Re: Which Water Pump   Which Water Pump Icon_minitimeTue Jun 30, 2015 10:52 pm
The cast iron impeller will probably flow better before cavitation than the stamped one. Do you remember which seller had it?
Which Water Pump
