 Compressor oil?
AzDon
PostSubject: Compressor oil?   Tue Aug 18, 2015 9:03 pm
I did a retrofit to r-134 to r-12 about six months ago, but it is becoming apparent that the compressor isn't going to survive......
The instructions with the new compressor do not give specific reccommendations for type and amount of oil, but says to refer to original specs.....
The FSM for my 91 OCC says to pour 2 ounces of "525" oil in the suction side and gives a procedure to coating all the internal surfaces....
My Questions are..... 1) Is "525" oil the correct oil to use for a r134a retrofit? 2) is 2 oz the total oil capacity of the system?
I have already replaced the accumulator/receiver/dryer twice since the retrofit as well as the orifice tube.....I have been using PAG150 oil on the advice of a counter guy......
http://v-driveboat.com
PostSubject: Re: Compressor oil?   Thu Aug 20, 2015 9:38 pm
On my BMW's when converted to r134 I've used Ester oil not sure why it would be different on our wagons. I prime the compressor until it is full before installing. Jeff
scoffman
PostSubject: Re: Compressor oil?   Fri Aug 21, 2015 6:37 pm
If you have all the necessary tools and equipment to do the conversion, then the short answer is you will need 6.0 ounces of PAG 150 oil for a 1991-1993 A/C system.
Now the long winded answer. . . Wink
If you haven't read the sticky Basic Principals of Auto AC do so. It has a plethora of knowledge and information. I posted a link in that thread that provides a guide as to how much of, and what kind of, refrigerant and oil to use. Look at page 5 of that linked .pdf to find the values for a Buick Roadmaster.
The compressor you should have is a GM R4 model and you will need to use PAG 150 oil. The amount of oil required for a 91-93 Buick Roadmaster A/C system is 6.0 oz. This stated value should be the same as what is mentioned in your FMS. However, you will be using a different kind of oil than the stated Mineral oil. Refer to the 94-96 Buick Roadmaster A/C system values to find the type of oil, PAG 150, which is compatible with the refrigerant R-134a.
As to the amount of refrigerant to add; with R-134a you should start with 70% of what is required then slowly add more to the system until you hit your desired air vent temperature. The linked .pdf states that the system requires 50 oz of R-12 so. . . I would start with 35 oz (50.0 X 0.70 = 35.0) of R-134a and slowly add more until I reach my desired vent temperature of 45 degrees. Note the cars air conditioning system should be set for maximum A/C (60 degrees on auto climate systems), and the blower set to maximum too. You should have the car idling at approximately 1500 RPM's as well.
I will mention that you need to replace the low pressure cut off switch that is located on the accumulator/dryer. You need one that's for R-134a not R-12. You could try to adjust the old one manually; however I could never get it to work properly. It's a $20 part and no headache trying to adjust it. Also don't forget to replace the accumulator and orifice tube while your at it. If your compressor is eating itself you should thoroughly flush the system too. Use a good quality flush solvent and blow out each A/C component for a long period of time. Check the old orifice tube for metal flakes when you remove it. Make sure there are no holes in the screens, if there are, then chances are you have metal flakes in the rest of the A/C system. If that's the case I would recommend replacing the condenser too. No mater how hard you flush the condenser you probably won't get all the metal flakes out of it due to the design of the coils. You should replace all the O-rings with new ones.
At the very minimum you will need an A/C vacuum pump, and gauges to do the job. Have fun. I had to replace the compressor, accumulator/dryer, O-rings, Low pressure switch, and orifice tube last year. This was after taking it to a mechanic who converted it from R-12 to R134a and didn't use the correct oil for the conversion, if he used any at all. Yeah the compressor chewed itself up after a couple of weeks of use. You know what they say. . . If you want something done right, do it yourself. It's been over a year and no problems yet.
AzDon
PostSubject: Re: Compressor oil?   Sun Aug 23, 2015 2:10 pm
Great information!....
My FSM is for 91 OCC, so no r-134 related info..... I AM ordering up a condensor, several orifice tubes, another new accumulator/dryer..... I didn't know about needing a different cycling switch for 134 (I do now!)....
Since the tube ends are tied into manifolds on the right side, I cant imagine ever successfully flushing it and replacements are only about $80 from RockAuto.....
One thing I DID remember to do for the conversion was to put a "high pressure cutout switch" in the port in the back of the compressor and "daisy chain" it into the clutch power wire...
At present, I've got A/C but I know the system is sick because after replacing the clogged orifice tube and sucking it down, I was only able to get 1 can in before the high-side pressure goes over 300........
It's damn hot here in AZ right now!
Compressor oil?
