 Heat and vent smells like coolant
Mattb
Heat and vent smells like coolant Empty
PostSubject: Heat and vent smells like coolant   Heat and vent smells like coolant Icon_minitimeSun Sep 13, 2015 6:24 pm
When I turn the heat or the vent on I smell coolant blowing into the car. The previous owner said the cooling system was recently flushed and all new fluid was added. The level in the tank is ok. He also told me the heat doesn't work great which is why I turned it on. My first thought was to get a new thermostat and flush the system again since I'm not sure if it was properly flushed or just drained and re-filled. If I smell coolant in the car that means there's a leak somewhere right? Most likely in the heater core?
PostSubject: Re: Heat and vent smells like coolant   Heat and vent smells like coolant Icon_minitimeSun Sep 13, 2015 6:40 pm
Heater core needs replacing.
Mattb
PostSubject: Re: Heat and vent smells like coolant   Heat and vent smells like coolant Icon_minitimeSun Sep 13, 2015 6:52 pm
That's what I thought. Thanks.
» Clogged coolant vent tube
» Leaking coolant over heating and no heat
» stalls in reverse and smells like oil
» Low Coolant Light On But Not Low On Coolant
» Have a boring life? Click here for your overdose of drama.... (both good and bad)
