 Standard Seat Tracks Conversion to Power?
Bert Slater
Bert Slater
Standard Seat Tracks Conversion to Power? Empty
PostSubject: Standard Seat Tracks Conversion to Power?   Standard Seat Tracks Conversion to Power? Icon_minitimeFri Sep 25, 2015 4:58 am
I have a 96 limited w/power seats and have found a beautiful seat unfortunately not power. So are there any power tracks that accept standard seats?
PostSubject: Re: Standard Seat Tracks Conversion to Power?   Standard Seat Tracks Conversion to Power? Icon_minitimeFri Sep 25, 2015 7:56 am
Yes just bolt them onto the seats. Usually you can just unbolt the power tracks and bolt them onto another seat.
Bert Slater
Bert Slater
PostSubject: Re: Standard Seat Tracks Conversion to Power?   Standard Seat Tracks Conversion to Power? Icon_minitimeFri Sep 25, 2015 9:22 am
i thought limited seats and standard seats took a different track/mounting? The bolt pattern to the wagon floor is same. The pattern on the seats/tracks to each other were different. So can i reuse the tracks formerly attached to limited seats for standard?
PostSubject: Re: Standard Seat Tracks Conversion to Power?   Standard Seat Tracks Conversion to Power? Icon_minitimeFri Sep 25, 2015 7:59 pm
The limited seats are different. You can only replace the seat/rail package as a unit. You will loose the lumbar, heat, and a number of other features. The connectors may be different as well, because the standard seats only activate from the door. You need the standard power seat tracks. The mounts on the floor are the same. I do not know where Melrose is in FL, so I can not recommend a junk yard. There are no B bodies in Orlando, or Daytona.
Bert Slater
Bert Slater
PostSubject: Re: Standard Seat Tracks Conversion to Power?   Standard Seat Tracks Conversion to Power? Icon_minitimeFri Sep 25, 2015 8:27 pm
thanks fred. besides b bodies, are there any other gm cars that use the same standard power tracks?
PostSubject: Re: Standard Seat Tracks Conversion to Power?   Standard Seat Tracks Conversion to Power? Icon_minitimeFri Sep 25, 2015 9:32 pm
In a simple answer, no.
» Power Seat Switch and Power Mirror Motor Lube?
» Front seat tracks.
» seat conversion
» Adding power to passenger seat
» Power seat motor replacement?
