 Normal zone on temp gauge for Caprice?
Steve Smith
Normal zone on temp gauge for Caprice? Empty
PostSubject: Normal zone on temp gauge for Caprice?   Normal zone on temp gauge for Caprice? Icon_minitimeWed Sep 30, 2015 5:51 pm
Just completely flushed the cooling system (radiator, heater core) using a kit bought on ebay (Prestone ).I'm used to the temp gauge and what's normal in the Roadmaster. Not used to the design temp gauge in the '94 Caprice. When the needle is in the middle area of the gauge, does that indicate a normal operating reading?
PostSubject: Re: Normal zone on temp gauge for Caprice?   Normal zone on temp gauge for Caprice? Icon_minitimeWed Sep 30, 2015 9:19 pm
It's the most vague gauge in history.
What year is your Caprice? If it's a 94-96, pull the real temp from the climate control and check that. It will tell you in actual units of degrees Canadian. As long as the gauge isn't red, you're good. Otherwise it's genuinely BS.
PostSubject: Re: Normal zone on temp gauge for Caprice?   Normal zone on temp gauge for Caprice? Icon_minitimeWed Sep 30, 2015 10:19 pm
What year is your Caprice? If it's a 94-96, pull the real temp from the climate control and check that BS.
Er,... caprice climate what?
PostSubject: Re: Normal zone on temp gauge for Caprice?   Normal zone on temp gauge for Caprice? Icon_minitimeWed Sep 30, 2015 10:28 pm
About a third of the way up appears to be normal on my 95 9C1. SO like Ray said, vague and open to interpretation.
PostSubject: Re: Normal zone on temp gauge for Caprice?   Normal zone on temp gauge for Caprice? Icon_minitimeWed Sep 30, 2015 11:19 pm
Oh yeah. Totally forgot about that - ha.
» Faulty Temp Gauge? Coolant temp sensor?
» Temp Gauge Not Working....
» Is this normal?
» no temp gauge in 94 FWB wagon. Any suggestions?
» Temp Gauge Reads Very High
