 door panel courtesy lamps
papa
PostSubject: door panel courtesy lamps   Wed Jan 13, 2016 3:24 pm
I'm thinking that I would like to install courtesy lamps in my Caprice doors. I have not actually seen a vehicle with them, only pictures. Do the lamps have a forward-facing lens that illuminates the map pockets in the door panels? Is any of the necessary wiring present on cars without the lamps? Thanks.
PostSubject: Re: door panel courtesy lamps   Wed Jan 13, 2016 3:51 pm
Yes and Yes. The front doors have small lenses in the door panels to light up the map pockets. The doors all have a plug in the middle under the panel to plug the lights into.
PostSubject: Re: door panel courtesy lamps   Fri Jan 15, 2016 1:11 pm
That sounds like a great mod, never heard of it BTW. Keep us posted please
papa
PostSubject: Re: door panel courtesy lamps   Fri Jan 15, 2016 3:16 pm
I guess I should have made it clear that I'm talking about the lights that came factory in some sedans. My wagon has the block-off/ filler plates instead.
PostSubject: Re: door panel courtesy lamps   Fri Jan 15, 2016 7:40 pm
It has been done. Chris "Stubby No Mods" did this on his Cappy wagon. Paging Chris!!! cbshea13!
PostSubject: Re: door panel courtesy lamps   Fri Jan 15, 2016 8:18 pm
This has been on my to do list for my rear doors since 2012
PostSubject: Re: door panel courtesy lamps   Sat Jan 16, 2016 9:50 pm
They take minutes to do. The wiring is already in the door for them, pop off the "blank" corner piece, plug light in, snap light in place. Done.
PostSubject: Re: door panel courtesy lamps   Sat Jan 16, 2016 10:49 pm
All you need is a pair of them in the right color for your car. What color is your interior?
papa
PostSubject: Re: door panel courtesy lamps   Sun Jan 17, 2016 7:55 am
My interior is blue. I would like to have the lights in the front and rear doors. I believe they are wired through the door jamb switches to come on when the doors are opened , but do they also come on when the interior lights are turned on with the headlight switch?
PostSubject: Re: door panel courtesy lamps   Sun Jan 17, 2016 8:10 am
What color of blue?
I believe they only come on when you open the doors.
PostSubject: Re: door panel courtesy lamps   Sun Jan 17, 2016 8:23 am
If possible and you find some, I would like to have 4 pieces to please, Fred. Dark blue leather interior.
PostSubject: Re: door panel courtesy lamps   Sun Jan 17, 2016 7:48 pm
They are on the same circuit as the dome lights so they will turn on with the headlight simmer switch as well.
» Moderator Control Panel
» Moderator Control Panel - Basket Option
» This Web page is parked for FREE, courtesy of GoDaddy.com.
» How to add the avatar in the User's Control Panel ?
» Can't find Admin Panel Link
