 How to replace radiator drain petcock??
andy caprice
How to replace radiator drain petcock?? Empty
PostSubject: How to replace radiator drain petcock??   How to replace radiator drain petcock?? Icon_minitimeTue Jan 26, 2016 2:36 am
Hi!
The (stock) radiator drain petcock on my '95 Caprice has been leaking a bit lately, so I decided to get a new one. It would be nice to just pop the old one out and new one in, letting as little coolant out and as little air in as possible.
So the question is, how is the petcock removed and installed? Does it come right out if I twist it to some specific position? Or, do I have to twist it to some specific position and then somehow drive the pin out, or something like that?
Thanks!
» Replace the current WYSIWYG editor with CKEditor
» Externally purchased domain name to replace forumotion domain
» Replace avatar with topic image to recent topic widget
» Replace text to emoticon using javascript
» fumoto drain installed on BT catch can...
