 oil cooler gasket removal
chunkyluver53
oil cooler gasket removal Empty
PostSubject: oil cooler gasket removal   oil cooler gasket removal Icon_minitimeWed Jan 27, 2016 5:22 pm
I am replacing the gasket and o-ring this weekend. I have read many posts about the oil cooler itself, but few tips about actual removal. Any hints?? If I remember, someone used a buffing pad on a die grinder? I imagine with what a PITA, everyone says it is,  this will be fun. I apologize.....I have a 96 rmw
PostSubject: Re: oil cooler gasket removal   oil cooler gasket removal Icon_minitimeWed Jan 27, 2016 8:25 pm
Not sure what your asking, but if you remove the oil cooler you will just have to get the standard LT1 adapter without the lines on it. These are not the same as the old 350 as they have a offset in them so the filter does not hit the cat.
If you are just removing the gasket buy a can of gasket remover at you local parts store and use a single edge razor with some care.
chunkyluver53
PostSubject: Re: oil cooler gasket removal   oil cooler gasket removal Icon_minitimeWed Jan 27, 2016 8:37 pm
I am just replacing the gasket. I have read what a pain it is to remove the old one, and wondered if anyone had concocted  a better solution than a razor blade.  "No school like the old school" I guess....☺
» Oil Cooler Adapter Removal
» 9C1 Tranny cooler and Engine cooler picz
» EGR gasket
» Head gasket
» Head Gasket Question
