 Bolt Pattern, and Offset for Wagons
94 Roadmaster Wagon
94 Roadmaster Wagon
PostSubject: Bolt Pattern, and Offset for Wagons   Thu Feb 25, 2016 2:08 pm
I know it seems I'm always asking what these are, but I really need to know now, as I want to purchase a set of wheels for some summer tires.  I did look at the "sticky'' above, and clicked on the one link, and I saw that the bolt pattern is 5x5, and the offset is 0-15 mm.  Is that correct?  The offset doesn't seem right.  That sounds like a FWD offset to me.  Plus, the website didn't ask if it was a wagon, and I thought that the wagon took a different wheel than the sedan.  Right?
Thanks,
John
http://www.lubedealer.com/nielsen
PostSubject: Re: Bolt Pattern, and Offset for Wagons   Thu Feb 25, 2016 5:18 pm
Shopping for the Impala SS will net you more results/choices to choose from with no issues. Happy hunting.
PostSubject: Re: Bolt Pattern, and Offset for Wagons   Sat Feb 27, 2016 1:27 pm
Low offset is certainly more common on RWD cars. Most FWD cars have higher offsets.
Your offset is a function of the width of the wheel and its backspacing. Wagons do not take different wheels than sedans.
» cần tìm pattern Khuê Văn Các
» cho xin mau pattern nay
» Xin pattern OA tháp nghiêng Pisa 90 độ
» [Hiroko Pattern] Vase - Chậu hoa 3D
» CẦN XIN MẪU PATTERN CỦA MERRY GO ROUND
GM Longroof Forum :: Longroof Tech :: Wheel & Tire section-
