 1995 Buick Roadmaster running issue
brainiac
PostSubject: 1995 Buick Roadmaster running issue   Tue Mar 29, 2016 8:29 pm
My RMW has leaked oil since I bought it five years ago. I've taken it to different mechanics and no fix. Now the car occasionally cuts out or has died while driving. The newest mechanic's best guess is that the oil leak is allowing oil into the distributor and causing intermittent loss of electrical contact, thus the engine dies.
Does this sound feasible? Also, he's not pushing to do an expensive repair when he's not certain that's the problem. Having to remove various parts to get to the distributor is estimated around $500.
Any ideas? Thanks.
PostSubject: Re: 1995 Buick Roadmaster running issue   Wed Mar 30, 2016 6:56 am
Have you tried cleaning up the engine yourself, and then positively identifying the location of the oil leak? There are not that many places for leaks that are common. It's likely one of those. I'd not assume that the oil leak is related to the running issue yet. The Optispark unit might be on it's last legs, but it does not need oil inside to be defective. Just bad luck and time.
A detail shop should be able clean the engine up without damage to electronics for about $100, which is what any good mechanic will charge you to poke at the car for 1 hr. If you clean the engine, and then place a large clean sheet of paper or cardboard under the car overnight, you may be a lot closer to locating the leak by morning.
» Running out of milk - help!
» 3 Month Old running out of mama's milk!
» Bill O'Reilly on the black / race issue.
» The Big Issue
» Log In Issue
