 Best way to clean throttle body?
Deadmanonduty
Best way to clean throttle body? Empty
PostSubject: Best way to clean throttle body?   Best way to clean throttle body? Icon_minitimeTue Apr 05, 2016 2:24 pm
I'm curious what is the best way to clean the throttle body on LT1? Engine has 80,000 miles on it, but its sat around a lot and I see the TB is black inside.
Is it as simple as spraying cleaner into it, or will that damage sensors? My previous car had an Idle Air Control valve that got damaged if you sprayed cleaner into TB, so I figured I would ask before hurting anything.
Thanks in advance!
» Graphic Design Section Clean Up
» Home Page and General Templates : Index Body / Index Box and Code
» How to clean your desktop, delete virus and malware?
» Border image around forum body
» [IMPORTANT] Mobile Version: Modification of the ID page-body in the CSS
