BuickRM
| Subject: Oil cooler function Fri Apr 08, 2016 7:21 am | |
| Guys, when I tried to seal my oil filter adapter assembly ( what should be finished tomorrow) I attempted to understand the function of the oil cooler. There is no oil thermostat at all which should control the oil flow through the cooler when oil temp. raises up. I can´t believe that the complete oil is going through the cooler even once it´s cold. But theres a spring- loaded bypass valve beside within the adapter. Could it be possibel that the cold oil with the way higher pressure opens this bypass to go directly into the engine and bypassing the cooler? When the oil pressure drops with higher temperatures, the pressure is too low to open the valve and flows through the cooler. Hardly to imagine that the pressure losses through the lines and the cooler might be lower that the required pressure to open the bypassing valve....I don`t know. Does anyone know surely the function? Would be a strange solution to control the flow via pressure losses, but really smart.
Udo | |
| Subject: Re: Oil cooler function Fri Apr 08, 2016 8:58 am | |
| - BuickRM wrote:
- Guys,
Udo Americans eh? strange,... but smart. | |
BuickRM
| Subject: Re: Oil cooler function Fri Apr 08, 2016 9:25 am | |
| ...sorry, I´m German. Maybe the speech wasn´t right...I meant the solution seems odd, but works well anyway. | |
JaySS Admin
Posts : 427 Join date : 2009-01-06
| Subject: Re: Oil cooler function Fri Apr 08, 2016 9:32 am | |
| Two separate systems.
Oil cooler is full flow all the time, no thermostat used.
Bypass is there to allow for a clogged oil filter.
Should the filter become excessively restrictive, pressure relief feature will lift to continue to provide engine with oil (albeit now unfiltered).
Otherwise bypass should stay shut regardless of temperature (assuming no foot-to-the-floor starts @ -40 degrees).
- J
| Subject: Re: Oil cooler function Fri Apr 08, 2016 11:40 am | |
| - BuickRM wrote:
- ...sorry, I´m German. Maybe the speech wasn´t right...I meant the solution seems odd, but works well anyway.
No worries alter,. i,m canadian,.my speeches are never 'right' sorry,.I should have given you the right answer as jay did,. It works even when its cold, because even tho it's direct flow,. oil will still find the path of least resistance,. which means the oil 'leaks' inside the engine will increase a little if the cooler flow is slower,. | |
paart
| Subject: Re: Oil cooler function Fri Apr 08, 2016 2:33 pm | |
| There are two bypass valves in the adapter. One will open if the oil cooler lines become clogged or restricted. The other is the oil filter bypass valve which will divert flow from the filter, if it becomes clogged. | |
paart
| Subject: Re: Oil cooler function Fri Apr 08, 2016 2:41 pm | |
| Pictures of the insides, and how to bypass the cooler lines. Scroll down a little. (I hate to link to "that" forum, but that's where I once posted the photos.) [You must be registered and logged in to see this link.] | |
| Subject: Re: Oil cooler function | |
