| Upgrades for 92 5.0 | |
+6Fred Kiehl lakeffect phantom 309 GSBULLDOG Andebe Im6sevenso 10 posters |
Im6sevenso
Posts : 5 Join date : 2016-05-24
| Subject: Upgrades for 92 5.0 Tue May 24, 2016 4:22 pm | |
| I just recently bought a 1992 caprice wagon and wanted to know if swapping out the 305 for a 350 is a good idea or not. | |
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 4:56 pm | |
| No replacement for displacement... | |
Posts : 313 Join date : 2010-12-24 Location : Memphis Tn
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 6:53 pm | |
| I am think there is a thread where someone did exactly what you are asking about . Getting old memory is failing me now lol . | |
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 8:42 pm | |
| what do you mean by a 'good idea?
Im6sevenso
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 8:50 pm | |
| Phantom309 by good idea I mean will the 350 with a few add ons be on in power terms or should I wait for a little bit more and try to get something bigger than that. I'm not trying to go win races i just want some nice power behind the pedal. | |
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 9:09 pm | |
| Simply get a 350 and the computer from the same donor vehicle and it won't be an issue. The harness should be identical. | |
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 9:37 pm | |
| all depends on your budget,.
sometimes it's just a lot easier to sell the wee tbi and buy a real,. er,.... LT1 car,.
A nice LS3 with 6l80e would do the job tho,.. | |
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 9:41 pm | |
Im6sevenso
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 10:40 pm | |
| Those two are expensive but are actually able to get now are they direct fit or would cost more money for me to set up inside a 92. One more thing the 6l80e was coming up as a trams from a Tahoe or did I just not look up the right part? | |
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 11:03 pm | |
| I put a 350 in both of my OCCs, and it was a big improvement. If you can get the 350 LO5 out of a 93 9C1, it will have a hotter cam, larger injectors, and 205 HP. Get the computer and Y pipe as well. You can also put an LT1 cam in the LO5 for a performance increase. It should work with the 9C1 computer, and is a bolt in. Another 5 HP can come from the 93 Fleetwood electric fans. You can hook one up to come on with the AC, and get a sensor from JEGS for about $40 to turn the other one on. It worked great for me.
Duals and headers are fairly simple. The only real mod is a hump in the driver's side of the trans support. You can get the muffler hanger from the right side, and bolt it to the left side for the left pipe. The holes are already there to mount the hanger. I dumped mine in front of the axle to make it easy.
If you put headers on the car, changing the starter is much easier. The Y pipe blocks the starter, and you have to remove the pipe or the triangulating brace for the rear lower A arm. | |
| Subject: Re: Upgrades for 92 5.0 Tue May 24, 2016 11:46 pm | |
| 4L80E was a later model tranny. My gut feeling is you may have issues with the "E" part of that Equation.
| Subject: Re: Upgrades for 92 5.0 Wed May 25, 2016 7:10 am | |
| If you are swapping in an LO5, check the wiring that runs under the engine. The wires are notorious for having cracked and melted insulation. It is a lot easier to fix when it is out of the car, and can solve a lot of strange problems. Cut and splice one wire at a time to minimize confusion. | |
| Subject: Re: Upgrades for 92 5.0 Wed May 25, 2016 7:37 am | |
| - lakeffect wrote:
- 4L80E was a later model tranny. My gut feeling is you may have issues with the "E" part of that Equation.
edit: The 91-93 were 4L60 BUT no "E" designation. The computer did not support the Electronic version until the LT1 came into play during the 94-96 models. | |
| Subject: Re: Upgrades for 92 5.0 Wed May 25, 2016 8:21 am | |
| Unless there is something wrong with it, why bother? The stock LO5 was rated for 10 more HP and not much more torque. I am leaving the perfectly running 305 alone until I have the money saved for the LS3/TR6060 that I really want in the car. | |
| Subject: Re: Upgrades for 92 5.0 Wed May 25, 2016 8:36 am | |
| The LO5 has 20 more HP, and 50 more Lb. Ft. of torque. The 9C1 LO5 has another 25 HP, and a little more torque. The cost, if you do the work, is about $400-500 for a pick and pull engine. Check your gear ratio as well. You may want to find a 3.42 or 3.23 rear. If you change rear ratios, get the VSS gears out of the car you are pulling the rear from. | |
Im6sevenso
| Subject: Re: Upgrades for 92 5.0 Wed May 25, 2016 8:43 am | |
| Well the body and interior are pretty good. It has a an exhaust leak. But my main concern is that the frame has rust | |
| Subject: Re: Upgrades for 92 5.0 Wed May 25, 2016 9:49 am | |
| Maybe just have fun with what you have,and start budgeting for a newer (LT-1)wagon. | |
| Subject: Re: Upgrades for 92 5.0 Wed May 25, 2016 10:54 am | |
| Frame rust is a deal killer. Drive it until it breaks. | |
Steve Smith
Posts : 392 Join date : 2010-08-04 Age : 69 Location : Trevose, PA ( north of Northeast Philly)
| Subject: Re: Upgrades for 92 5.0 Wed May 25, 2016 4:58 pm | |
| If possible, test drive a B body wagon or sedan with an LT1 and compare. You might be looking for a '94-'96 model sooner than you think. On average your looking at a 1.5 second difference in the 1/4 mile to put it in perspective. | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 11:00 am | |
| - Fred Kiehl wrote:
- The LO5 has 20 more HP, and 50 more Lb. Ft. of torque.
TBI 305 is 170hp/275lbs. TBI 350 is 180hp and similar torque. 9C1 cars bumped that to about 205hp/300. | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 11:04 am | |
| - Steve Smith wrote:
- If possible, test drive a B body wagon or sedan with an LT1 and compare. You might be looking for a '94-'96 model sooner than you think. On average your looking at a 1.5 second difference in the 1/4 mile to put it in perspective.
I daily my 95 and other than a slight increase in oomph to get around traffic I see very little difference between it and my TBI 350. People really need to let this whole LT1 superiority go. | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 12:58 pm | |
| The 305 is supposed to have 140 HP. | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 1:36 pm | |
| Might be relative to production years or marketing ploys.
If you want balls, try a 400 block With a Holley Street Ram (HSR) set up. | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 2:36 pm | |
| - Andebe wrote:
- No big difference??? Yet in your own signature,referring to the LO5,you say,"Coming soon:More smallblock." Clearly its not enough.
Swing and a miss. You see, when you have an engine that doesn't run, and then build a new one that does you get "more" small block. But A for effort on your detective skills. - Fred Kiehl wrote:
- The 305 is supposed to have 140 HP.
Lol. In what year? 1961? But my GM FSM must be wrong because who would know better than GM how many horsepower their cars had? | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 3:14 pm | |
| Why bother to quibble about specifics of a few HP here or there when there were new 25 years ago. . The real issue is if you want more now in 2016, it's your car, so do want you can afford, and whatever you damn well please that will make you happy.
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 9:14 pm | |
| - lakeffect wrote:
- Why bother to quibble about specifics of a few HP here or there when there were new 25 years ago. . The real issue is if you want more now in 2016, it's your car, so do want you can afford and whatever you damn well please that will make you happy.
Amen ! I couldn't agree more . Lol | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 9:30 pm | |
| - Cadet57 wrote:
I daily my 95 and other than a slight increase in oomph to get around traffic I see very little difference between it and my TBI 350. People really need to let this whole LT1 superiority go. a slight increase in oomph,.. well,.. there you have it,.. from our most sensitive tbi owner,.. | |
Steve Smith
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 9:47 pm | |
well,.. there you have it,.. from our most sensitive tbi owner,..[/quote]
The difference between my '96 Roadmaster with a 15.54 @ 89 m.p.h. and my '94 Caprice with a 15.47 @ (just under) 89 m.p.h. is not what I consider a "slight increase in oomph" difference when comparing them to either the 170 hp. 305 or the 180 h.p. 350s in the 1991-1993 model year wagons. The TBI 350 engines (on You Tube) run very low 17s in the 1/4 . Where hundredths of a second matter, 1.5 seconds difference is substantial. To put it another way, my former 2007 (stock) Monte Carlo SS ran a 13.99 in the 1/4. That's approx. 1.5 seconds quicker than my Caprice's best. I definitely don't think of the performance difference between those two Chevys as the SS having "a SLIGHT increase in oomph".
Next............... | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 10:00 pm | |
| My best has been a 14.189 time and 96.87mph, but not on the same run.
From my signature below you can tell this was on a totally unmodified, bone stock, 305 vehicle while hauling several sheets of plywood from Home Depot.
OK, I'm lying. It was drywall from Lowes. So sue me. | |
Steve Smith
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 10:04 pm | |
| - lakeffect wrote:
- My best has been a 14.189 time and 96.87mph, but not on the same run.
OK, I'm lying. It was drywall from Lowes Time slip proof? video of those runs? 180 hp. BONE STOCK you say? Nah. No way sorry. Maybe with a 60 mph tail wind down the side of a mountain. | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 10:12 pm | |
| Read the signature line below this, where it says Shammoo, Prince of Whales You can see my wagon is totally unmodified show room bone stock in every way imaginably possible. Still has the original tank of gas in it. Ashtray has never been used. OK, it doesn't have an ash tray, but that's not the point. Down here [You must be registered and logged in to see this image.] | |
| Subject: Re: Upgrades for 92 5.0 Fri May 27, 2016 10:19 pm | |
Posts : 730 Join date : 2013-11-10 Age : 34 Location : Columbus, Ohio
| Subject: Re: Upgrades for 92 5.0 Sat May 28, 2016 4:48 pm | |
| Between the torque difference of the 350 and the 305, the deeper gears used in the TBI cars, a towpack TBI and a LT1 with a standard diff are probably pretty close. TBI heads suck harder than a homely girl on prom night and run out of breath like an asthmatic kid, during allergy season. LT-1 heads breathe much better. Our cars are very heavy,still debating on Olds BB or Iron LSx engine for my engine swap even though the L05 is healthy and still surprises people, probably because they expect a total slug. | |
| Subject: Re: Upgrades for 92 5.0 Sun May 29, 2016 10:36 am | |
| Stew,check out Harris performance for a few ideas to gain some "free"hp on the tbi. | |
| Subject: Re: Upgrades for 92 5.0 | |
