 93 RM TBI runs rough - no codes - nevermind
jbol
93 RM TBI runs rough - no codes - nevermind Empty
PostSubject: 93 RM TBI runs rough - no codes - nevermind   93 RM TBI runs rough - no codes - nevermind Icon_minitimeFri Jul 07, 2017 7:07 pm
turns out it was a bad negative battery connection Embarassed
coughs and shakes  after it warms up a little bit
worse going up hills
idles rough at lights
smooths out some at around 2500 rpm +
runs better on highway if I keep it out of overdrive(?) (higher rpms) does this eliminate fuel pump?
replaced fuel filter a year ago
pulled one plug and it looked like new
not the air filter
no codes flash so I am looking for possible things to not check/replace
is there a good diagram on where to look for vacuum leaks?
thanks
» TBI CEL - no codes, runs great
» Huge oil leak at front of LT1 motor after water pump replacement
» 95 lt1 running rough
» Engine Intermittently dies, runs rough then dies.
» Rough Ruby
