 dodge shocks on a b/d body
PostSubject: dodge shocks on a b/d body   Mon Jun 20, 2016 11:56 pm
caddy needed front shocks so bad it was embarrassing,.turned out the drivers front shock was empty,.
so i ordered a set of dodge van shocks,. which are a little beefier than stock,. i bought monroe's, the medium duty ones,.
The bottom bolt holes need to be elongated to match the narrower gm bolts,. but length wise they are perfect,
the barrel being a little fatter they have to go in thru the wide part then slide into place going up through the lower control arm,.
car is so much nicer to drive,.
they hold well and are not as expensive as the HD shocks for the car,. or a premium name brand
» Maddie's Body Discovered? Stephen Birch/Mccannfiles
» Missing woman's body found in suitcase in garage of her home.
» Experimental Body Armour
» Body of Sierah Joughin, Who Vanished While Riding Bike, Found
GM Longroof Forum :: The Longroof Lounge :: Fleetwood-
