 96 RMW coolant level sensor?!!
TrackRacer
96 RMW coolant level sensor?!! Empty
PostSubject: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeSun Aug 14, 2016 12:41 pm
Hey guys, my low coolant light was recently triggered although ofcourse the resovoir is full. The coolant level obviously is bad. I cannot locate the sensor anywhere online. It mounts to the bottom of the coolant resovoir. Ive found pictures of the sensor but no actual sensor for sale! Where can i buy one?
PostSubject: Re: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeSun Aug 14, 2016 12:55 pm
I have seen others comment that if you whack it hard it will start working again.
TrackRacer
PostSubject: Re: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeSun Aug 14, 2016 1:09 pm
I really prefer the method of replacing it ha ha
PostSubject: Re: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeSun Aug 14, 2016 1:57 pm
You can waste your money if you like, but pounding on the reservoir will quickly free up that stuck float. Works every time.
PostSubject: Re: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeMon Aug 15, 2016 10:50 am
Senior member advice = been there,done that. Happy whacking...err,banging...well,you get the gist of it. Rolling Eyes
PostSubject: Re: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeMon Aug 15, 2016 11:15 am
The sensor is molded into the tank and is not serviced separately. A complete reservoir is PN 12528777 and is just shy of $100.00.
It might be a good idea to double check the wiring and connector.
PostSubject: Re: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeMon Aug 15, 2016 9:51 pm
not worth the money,.pull reseervoir, put some clr in it,. and shake it around,. cleans the rust out of it,..
PostSubject: Re: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeMon Aug 15, 2016 9:55 pm
Or just unplug it. The light will go out. Don't let it get empty.
PostSubject: Re: 96 RMW coolant level sensor?!!   96 RMW coolant level sensor?!! Icon_minitimeMon Aug 15, 2016 10:44 pm
I had the same problem with my 96 Roady right after I bought it. Posted the same question here, Jayoldschool posted same fix, and it worked. Laughed my ass off. It's never come on again after 4 or so years.
» Sub-levels (subform) - how to put the word in front of the sub level links?
» Level 200 and what hapend
» Warning level icon
