Big Jack
Posts : 81 Join date : 2016-09-07 Age : 30 Location : Halifax, Nova Scotia, Canada
| Subject: 2nd & 3rd row seat removal Thu Sep 15, 2016 1:24 pm | |
| Can someone post a photo showing how to get the 2nd row seat back out? Also 3rd row seat & seat back? There is also the piece that is between the seatback hinges, I took out the 3 bolts, but it still won't lift up off. Any guidance here would be greatly appreciated.
Thanks | |
| Subject: Re: 2nd & 3rd row seat removal Thu Sep 15, 2016 2:02 pm | |
| Hi Big Jack
2nd row seat: sounds like you figured out the seat part, but if you haven't, push the seat part in, lift up and out. There are two hooks that you have to unclip from. The back of the seat has a spring loaded pivot point "thingie". Towards the bottom of the seat back, where it pivots, push it in, away from the stud that the seat pivots on. After you've cleared the stud, pull the seat back towards you. Then slide it off of the stud on the other side. If I remember correctly, you do this on the passenger side. It's easier than I make it sound.
As for the 3rd row seat, I only can help you with the bottom. It's the same as the second row bottom.
| Subject: Re: 2nd & 3rd row seat removal Thu Sep 15, 2016 7:02 pm | |
| the 3rd row top has 2 screws one one each end. if the seat is in uprite position there is some vynol across the top if u lift it up there is a chrome screw on each end. unscew it then it will fall toward the tailgate then just lift it up. the screws are usually on goofy angels. so whem u put it back it tends to be a pain | |
Big Jack
| Subject: Re: 2nd & 3rd row seat removal Sat Sep 17, 2016 6:43 pm | |
| Subject: Re: 2nd & 3rd row seat removal | |
