 Water pump driveshaft play
Big Jack
Water pump driveshaft play Empty
PostSubject: Water pump driveshaft play   Water pump driveshaft play Icon_minitimeTue Sep 27, 2016 11:57 pm
Hi all,
I'm in the process of replacing my water pump.
With the old pump removed, there is noticeable play (maybe 0.01" - 0.20") in the end of the water pump driveshaft when I push on it radially.
Since the front support bearing (inside that water pump) is currently absent, I would think this play is to be expected & isn't cause for concern.
Car has 73000 miles, so I assume the rear bearing should still be OK.
Am I wrong here? Do I need to replace the bearing on the water pump drive shaft behind the drive gear?
Thanks.
PostSubject: Re: Water pump driveshaft play   Water pump driveshaft play Icon_minitimeWed Sep 28, 2016 7:46 pm
You are right,. its fine,.
» Avatar for Bleach Role-Play Forum
» Medieval Role-Play
» Role Play Character Post Template
» Role play [Pets]
» Auto-play Youtube Videos
