 Speaker cuts out when I turn
DPM96C
Speaker cuts out when I turn Empty
PostSubject: Speaker cuts out when I turn   Speaker cuts out when I turn Icon_minitimeSat Oct 15, 2016 7:08 pm
My pretty-new-to-me 92 Roadmaster has the stock speakers in it, and the driver's side door panel is messed up in all kinds of ways. One of them: The speaker cuts out constantly, or maybe cuts in constantly at this point.
It'll go in and out when I make a right turn, or when I push in on my crappy door panel. I'm probably going to buy new speakers anyway, but does this sound like a speaker issue or something else? I had the head unit (one of the 1.5 DIN Pioneer models) out to install an AUX jack, so I don't think it's a connection going into the head unit, but I could certainly be wrong.
PostSubject: Re: Speaker cuts out when I turn   Speaker cuts out when I turn Icon_minitimeSun Oct 16, 2016 9:57 am
You might want to take a look at the wiring boot between the door and the body. Check for any physical damage. A split or cracked boot will eventually damage the wiring within.
PostSubject: Re: Speaker cuts out when I turn   Speaker cuts out when I turn Icon_minitimeSun Oct 16, 2016 10:46 am
Given that the cut out is conditional, I'd check to see if it is a wire swinging and rubbing to a point where it either disconnects or shorts.
DPM96C
PostSubject: Re: Speaker cuts out when I turn   Speaker cuts out when I turn Icon_minitimeSat Mar 25, 2017 2:00 am
In case anybody has the same problem I did: The problem turns out to have been much dumber, but also much easier, than I feared.
I finally pulled the speaker to replace it with a new one last night, and it turns out the contacts going out to the speaker were pried open on one side; when I would turn, the speaker plug would sometimes touch both sets of contacts and turn on. I pushed them back together and everything sounds—well, not good, because it's the stock speakers, but right.
» OCC 4 speaker instalation
» Speaker recommendations
» Need Help! Crackling Speaker
» OCC speaker polarity
» Speaker baffles?
