 Motor Mount
Skier
PostSubject: Motor Mount   Fri Dec 30, 2016 9:46 pm
I may need to replace my oil pan so may  as well replace the motor mounts.  What brand is the best?  On Rock Auto price runs from $1.59 to $93 for ACDelco.  Are the ACDelco mounts that much better or just outragesley over priced?
'95 RMW
PostSubject: Re: Motor Mount   Sat Dec 31, 2016 8:11 am
Whats wrong with your motor mounts,..?
PostSubject: Re: Motor Mount   Sat Dec 31, 2016 10:53 am
You are looking at making some tools to reach the bolts for the mounts. I replaced mine with the lower suspension arms off, and it was a PITA. The lower bolts are almost impossible to reach with the lower arms installed. Upper bolt can be reached through a hole in the front of the cross member. I got a set of urethane inserts and reused the clamshells. You have to make sure you get the inserts in right side up. I would never try doing it myself with the lower suspension arms in place. The cost of having a mechanic do it is cheap.
Skier
PostSubject: Re: Motor Mount   Sat Dec 31, 2016 4:06 pm
After talking to my youngest brother, I will leave the motor mounts in they are not broke.
PostSubject: Re: Motor Mount   Sat Dec 31, 2016 4:20 pm
Good choice.
Motor Mount
» Should motor racing be banned?
» NEW CANADIAN VETERANS MC WILL SEE IS DEBUT VERY SOON
» Woman who murdered her son found dead in Mountjoy women's prison
