 Need door panel help.
Need door panel help. Empty
PostSubject: Need door panel help.   Need door panel help. Icon_minitimeMon Jan 09, 2017 10:40 am
Aside from the normal cracking/splitting everyone gets on the bottom portion on the drivers door. (1994 Roady) My handle pulled out of the door on one end. It looks like a threaded spike. Does it have a nut,or go into a plastic female piece? Thanks in advance. scratch
PostSubject: Re: Need door panel help.   Need door panel help. Icon_minitimeMon Jan 09, 2017 10:59 am
The grab handle itself is bolted to the inner door with large screws under the straps. You carefully peel back the ends of the straps, and there is a large Phillips screw on each end. The handles also have little hooks on the end that are supposed to fit over the ends of the plastic trim there to.
I just had my panel off yesterday in the rear. The screw goes into a metal clamp mounted on a metal strap that is riveted to the door. You can see the metal strap and dark clamp in this pic.
Need door panel help. 15873125_10211720787845886_7721344095742165296_n
My thought is you will need to remove the front door panel and just replace that clamp. I just slides off the metal strap.
Hope that helps!
PostSubject: Re: Need door panel help.   Need door panel help. Icon_minitimeMon Jan 09, 2017 11:04 am
So I will need to end up re-rivetting said strap to door?
PostSubject: Re: Need door panel help.   Need door panel help. Icon_minitimeMon Jan 09, 2017 11:25 am
No you just need the little clip that that slides over the metal strap inside the door. You can see it in the upper-left corner of that pic I posted above. There is a bright silver metal strap riveted to the door, and a dark rectangular clip with a hole in the middle, which is what that larger Phillips screw mounts too.
Can you see it in the pic above? Just to the left of the rolled-up plastic splash cover, on the upper-left of the door. You don't need the strap, just the clip, which should slide right off.
You might also look at the threads of your Phillips screw. It's possible they might me stripped and you could just use a different screw and some Loc-Tite to re-mount the pull handle.
Good Luck!
PostSubject: Re: Need door panel help.   Need door panel help. Icon_minitimeMon Jan 09, 2017 12:02 pm
The part is called a speed nut. They have a small tang that catches on the hole to keep them in place when you remove the screw. If the tang is bent or broken the speed nut will fall off. You can get them at the local parts store. Take the screw with you to make sure you get the correct size.
PostSubject: Re: Need door panel help.   Need door panel help. Icon_minitimeTue Jan 10, 2017 10:47 am
Fixed. Thanks again guys for the help. Im afraid I am now in the market for a new door panel. I can nurse this one until it gets warm outside. Rolling Eyes
PostSubject: Re: Need door panel help.   Need door panel help. Icon_minitimeTue Jan 10, 2017 10:51 am
Well good to hear the strap is on!
