 TBI 355 No Fuel
TBI 355 No Fuel Empty
PostSubject: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSat Feb 25, 2017 3:03 pm
Finished my 355 crate motor swap. Everything bolted down and plugged in. Go to start it up, spark, crank but no fuel coming out the injectors. Fuel pump does NOT prime at key on. It does however pump all the way TO the throttle body when 12v is applied to it at the test plug. The following has been done.
-Grounds cleaned/inspected
-pump relay swapped with known good
-pump fuse checked
-New dizzy ICM swapped with previously known good dizzy/icm (both with Delco ICM's)
-New cap/rotor
Injectors were rebuilt appx 2 years and 12k miles ago.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSat Feb 25, 2017 9:46 pm
Check your oil pressure sender.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSun Feb 26, 2017 3:10 pm
Sender and pigtail are brand new
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSun Feb 26, 2017 3:30 pm
Are you getting voltage for the energizer coil of the fuel pump relay? Are you getting voltage to the high side of the relay? Are you getting a good ground for the relay when you turn the key on?
The wires under the front of the engine are subject to a lot of heat, and sometimes will have insulation issues. Your signal from the oil pressure sensor may not be getting to the relay.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSun Feb 26, 2017 5:01 pm
IS there a security system involved?
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSun Feb 26, 2017 5:06 pm
Nope.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSun Feb 26, 2017 8:41 pm
bench test it. I've bought too many brand new parts that were more dead than a parrot in a Monty Python sketch.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeMon Feb 27, 2017 11:03 am
You may be getting fuel but maybe not enough fuel. Car's been sitting a while, with fuel in the tank? Maybe bad feed hose, fuel pump may be sticky from sitting.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeMon Feb 27, 2017 11:21 am
Thats what ive been thinking BUT, the car was started and drove into the garage in October. So really it hasn't been sitting THAT long, really no more than when i'd put it in storage for the winter.
Also, jumpered the oil pressure sender wiring. It has power and primes the pump so I now know the wiring TO the OPS is good. Waiting for UPS to deliver my noid light to see if we have injector power.
occ6.6
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeTue Feb 28, 2017 8:58 pm
does the check engine light come on when you turn the key to run? if it doesn't you either have no battery 12v to ecm or no 12v ignition fed,check your fuses to make sure they aren't blown.also you can use a test light to check for 12 volts at injector plug if you do probe opposite wire on injector plug with test light connected to battery positive , crank engine if light flashes you have pulse .oil pressure switch is just a back up in case f.p. relay fails,you will usually experience a extended crank time when this occurs & obviously not hear the pump prime at key on.also check the 2 wire lead from ignition coil to dist,should have 12volts on red or pink wire to dist I have seen many with bad connections at coil end in the moulded connector . if you don't have 12v there dist wont be alive to trigger injectors but can still have spark,seems impossible but been there done that.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeFri Mar 03, 2017 5:35 pm
CEL/ other dash lights come on at key on/run. No injector power/pulse via noid light. I have power to the distributor and coil.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeFri Mar 03, 2017 6:02 pm
Check fuse #11, and check that the injectors are being grounded by the computer.
occ6.6
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeFri Mar 03, 2017 6:16 pm
like fred said check # 11 if its good you should have power on red wires at injectors , use a test light or voltmeter.if you do not have battery voltage on red wires & fuse is ok you have a broken wire somewhere.try jumping red wires to another power source (battery positive will work in a pinch) & do the noid light thing ,if she flashes plug injectors in & try to fire it,if it runs find your open circuit.if it does run you will have to disconnect your temporary jumper to shut it down.good luck
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeFri Mar 03, 2017 6:25 pm
You do not have to remove your jumper to shut it down. Just turn the key off. The gas and spark will stop, and the computer will stop grounding the injectors.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSat Mar 04, 2017 11:59 am
So, went under/behind the engine adjusted/ rechecked the PS and DS head grounds. NOW, no CEL at key on. Just digital speedo and seat belt light. I have 12v at the injectors. So now I'm thinking something in the grounds? The fueses are all good.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSat Mar 04, 2017 4:04 pm
I would check the grounds on your driver's side A pillar.
occ6.6
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSun Mar 05, 2017 8:57 am
are the ground points on the heads free of paint? is the ground to the body from the battery good? check the head grounds to see if the wires are not broken right where they crimp onto eyelet.the insulation might look fine but the wire inside could be broken,give the wire a little tug ,if it pulls away from eyelet you might have found issue.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSun Mar 05, 2017 9:28 am
He said he already fixed the engine issues by redoing the grounds at the back of the heads to the firewall. His issue now is in the interior.
PostSubject: Re: TBI 355 No Fuel   TBI 355 No Fuel Icon_minitimeSat Mar 18, 2017 10:14 am
is it up and running?
TBI 355 No Fuel
