 Coolant bleeder valve
Haze5736
PostSubject: Coolant bleeder valve   Sat Mar 11, 2017 7:37 am
I read the sticky titled, Beginner's Guide to Making Your B Body Faster. I have a question about installing a ball valve in place of the bleeder screw on the t-stat housing. In the fall I drained and filled the cooling system and really didn't like the mess from the coolant dripping over the opti during the bleeding procedure. I had rags stuffed everywhere but it was still quite a mess and a lot seeped through the rags and onto the opti.
I have not been able to find a ball valve. Searching online has proven to be rather difficult and I'm not sure why. I saw a post somewhere that after some time, which I don't remember but it seemed like a short amount of time, the ball valve was ruined and would not open. Are people still doing this mod? If so, where do you find a ball valve that will hold up over time?
Thanks.
PostSubject: Re: Coolant bleeder valve   Sat Mar 11, 2017 8:05 am
I did something similar using a couple bucks worth of fittings from Home Depot. Worked perfectly.
Haze5736
PostSubject: Re: Coolant bleeder valve   Sat Mar 11, 2017 9:03 am
What valve did you use? I couldn't find any 1/8" valves at Home Depot.
PostSubject: Re: Coolant bleeder valve   Sat Mar 11, 2017 3:17 pm
Don't remember the numbers cause it was nearly a decade ago, lol.
It wasn't a valve like you see people selling. Just a simple drain valve. It was a little tall but cleared everything and got the job done Smile
Gerome
PostSubject: Re: Coolant bleeder valve   Sun Mar 12, 2017 12:54 pm
I hope this helps you out . This is something I downloaded some time ago . Just happen to be looking through some old pics . Hope it helps .
PostSubject: Re: Coolant bleeder valve   Sun Mar 12, 2017 2:51 pm
Winner, Winner......
Haze5736
PostSubject: Re: Coolant bleeder valve   Sun Apr 02, 2017 6:07 am
Thanks. This is very helpful.
» OpenID sign in using Steam (Valve)
