 Oil cooler adapter
Don in MO
Don in MO
PostSubject: Oil cooler adapter   Sat Apr 01, 2017 5:21 pm
Got the car apart. Replacing the radiator, water pump, upper and lower rad. Hoses, and oil cooler lines.
My question is: I've removed the hex head bolts in the oil cooler adapter. Do I need to remove the hex above the oil filter threads? Is that threaded into the motor? Because with those two hex headed bolts out, it's still solid!
Thanks
Don
Don in MO
Don in MO
PostSubject: Re: Oil cooler adapter   Sat Apr 01, 2017 6:37 pm
Did a search and found the answer. Put the filter back on and rubber mallet it loose. Of course the only gasket set I have is the Dorman set!
Taking pics will try to post after I'm done.
Don
Don in MO
Don in MO
PostSubject: Re: Oil cooler adapter   Sun Apr 02, 2017 12:29 am
Oil cooler adapter
» nice styrofoam cooler free to a good home - pick up on UWS
