 Wet set belt
Wet set belt Empty
PostSubject: Wet set belt   Wet set belt Icon_minitimeFri Apr 21, 2017 10:36 am
Torrential rains last nite,wet drivers seat belt this morning. No visible signs of rot,where do I look to fix this? scratch
Wet set belt Empty
PostSubject: Re: Wet set belt   Wet set belt Icon_minitimeFri Apr 21, 2017 11:19 am
Leaking roof rack nuts, water goes down B pillar lets belt get wet.
Wet set belt Empty
PostSubject: Re: Wet set belt   Wet set belt Icon_minitimeFri Apr 21, 2017 3:23 pm
I have the same issue. It is tough to find the leak. It must be above the belt. It could be the seam that the top door seal fits over. The only roof rack nuts loose that would cause that is the front set on a Caprice. The others are below the top of the curve of the roof, and would run back to the rear of the car on the headliner unless there is a vertical piece blocking the water, and forcing it front.
Wet set belt Empty
PostSubject: Re: Wet set belt   Wet set belt Icon_minitimeSat Apr 22, 2017 10:14 am
Thanks guys,I will give it a hard look over when things get dryer.
Wet set belt Empty
Wet set belt
» Belt Noise?!?
» Squeeky belt
» Seat belt for 95 RMW
» Collected RMW stuff for 24 years--time for it to go!---Updated!!
» fan belt / mechanical fan
