| possible rear disc swap over? | |
| Subject: possible rear disc swap over? Wed Jun 14, 2017 3:49 pm | |
| First off, does any know if our rear axles use a "c" clip? I found an upgrade for 73-94 GM 5x5 truck axles PROVIDED that they use a "C" retaining clip. Here's the link. It's the last item in the GM section. My recollection is that GM may have simply stuffed the heavier truck axle under our wagons. to use the 5x5 spacing. So I'm wondering if this is want many of us have been waiting to find without the beed to buy larger diameter wheels. http://www.ecihotrodbrakes.com/rear_discbrake_conversions.html | |
| Subject: Re: possible rear disc swap over? Wed Jun 14, 2017 11:36 pm | |
| Do the 255s fit in the wheelhouses? | |
| Subject: Re: possible rear disc swap over? Thu Jun 15, 2017 12:08 am | |
| Good question. I am running 295's on the rear (TIRES)
| Subject: Re: possible rear disc swap over? Fri Jul 07, 2017 3:16 am | |
| Yes, the rear axles are held in with C clips. | |
Gerome
Posts : 73 Join date : 2017-02-06 Location : Memphis Tn .
| Subject: Re: possible rear disc swap over? Sun Nov 05, 2017 12:38 am | |
| - lakeffect wrote:
- First off, does any know if our rear axles use a "c" clip?
http://www.ecihotrodbrakes.com/rear_discbrake_conversions.html Did anything ever come of this ? | |
| Subject: Re: possible rear disc swap over? Sun Nov 05, 2017 6:26 am | |
| I never spend the money on it to find out.
| Subject: Re: possible rear disc swap over? Sun Nov 12, 2017 7:59 pm | |
| Subject: Re: possible rear disc swap over? Tue Nov 14, 2017 10:44 am | |
| Those look nice Eric. D52? | |
| Subject: Re: possible rear disc swap over? Wed Nov 15, 2017 12:46 pm | |
| Common GM front calipers. | |
| Subject: Re: possible rear disc swap over? | |
