 GM AM/FM/CD Power Antenna
GM AM/FM/CD Power Antenna Empty
PostSubject: GM AM/FM/CD Power Antenna   GM AM/FM/CD Power Antenna Icon_minitimeThu Jun 22, 2017 10:46 am
Ok...the 78 Electra Wagon has the factory AM/FM/CB power antenna...and it's currently down...I've never seen it move, since the radio was no good. I found the way to test it, see here:
Power hookup for testing....
To raise
Green(+) Gray(-)
To lower
Green(-) White(+)
SO knowing I'm installing a new aftermarket Kenwood this weekend, is it possible, if it works, to use the original antenna? I know the antenna wire will plug in, but how do I wire this thing? I'm thinking the aftermarket radio will just have a single power wire for the antenna.....
Thoughts? Tips? Anyone done this?
GM AM/FM/CD Power Antenna 19417546_10213359216085568_6814994611370204100_o
PostSubject: Re: GM AM/FM/CD Power Antenna   GM AM/FM/CD Power Antenna Icon_minitimeThu Jun 22, 2017 11:09 am
Facebook is amazing...   I just got this in a Message:  The grey/white/green wires work in conjunction with the relay to raise and lower the antenna.
no single wire is for raising or lowering the antenna.
For up....
green (+)
gray (-)
For down....
white (+)
green (-)
What you need to find in the vicinity of the radio are orange and yellow wires.
The orange is constant hot, allowing the antenna to go down when the car is turned off.
Yellow is the TRIGGER that should go to your new radios antenna lead.
GM AM/FM/CD Power Antenna 19388750_10213359437171095_4902840926810870760_o
