 Bleeding the Cooling System
Wagon Collector
Wagon Collector
Bleeding the Cooling System Empty
PostSubject: Bleeding the Cooling System   Bleeding the Cooling System Icon_minitimeWed Jul 07, 2010 9:38 am
Okay... so I've had LT1 cooling systems apart a billion times...
This time, when I buttoned up the '94, I bled the system per usual - while adding coolant I had the valve cracked, then I started the car w/o a cap, let it warm up, bled it again, put on the cap, drove it, bled it again. This is usually all it takes.
Parked it yesterday, and it puked up a bunch of coolant. I pulled the expansion tank cap, and it was very low. Added some coolant, and grabbed the cap from another car because the cap had a little spring that was out of place - I think it was bad and the system couldn't achieve pressure.
So... now all seems fine, but I'm getting the waterfall sound at the heater core. I've bled the system a bunch of times, and I just can't seem to get the noise to stop.
Any suggestions? Is my heater core perhaps clogged? It (the heater core) is only a couple years old, but I guess anything is possible!
Thanks in advance!
PostSubject: Re: Bleeding the Cooling System   Bleeding the Cooling System Icon_minitimeWed Jul 07, 2010 1:11 pm
You may of tried this but I usually jack the front of the car up as far as I can and then go through the bleeding process. Doing it this way I can normally do it in one shot.
» pressure tester for bleeding the cooling system
» 160 Thermostat with stock program question
» Cooling system hoses. Are there any hidden ones?
» Cooling system leak on TBI
» i've got the cooling system blues...
