 filthy coolant reservoir tank
frederickflintstone
frederickflintstone
filthy coolant reservoir tank Empty
PostSubject: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeSat Oct 28, 2017 1:03 am
Anyone have any suggestions for cleaning out the rust on the coolant reservoir tank? I used vinegar to flush the engine but the reservoir is still brown inside. I am going to take it off for more access. Anyone else done this before?
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeSat Oct 28, 2017 1:13 am
Remove tank, drain, dry. Put in some sort of cleaner, and a bunch of ice. Tape openings. Shake a lot. Drain. It will be cleaner. If not clean enough, scuff with Scotchbrite, paint with satin black Krylon Fusion. It will look factory like on the Corvettes. I did this on my SS years ago, along with the washer tank. Really cleans up the engine compartment.
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeSun Oct 29, 2017 6:16 pm
If interested, still available new. 12528777. Usually the best price can be found on E-bay.
Cosmos366
Cosmos366
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeMon Oct 30, 2017 2:19 am
FYI, It's on sale at gmpartsdirect.com right now for $79.38.
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeMon Oct 30, 2017 1:59 pm
Thanks, I didn't think the part was available.
I can say a soak in pure vinegar does not work well.
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeMon Oct 30, 2017 2:43 pm
The ice trick works well, but use crushed ice. Gets in all the corners better. Also, I've have good luck with Purple Power cleaner.
Eds rmw
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeMon Oct 30, 2017 11:14 pm
Put sand/ gravel in it, your cleaner of choice. Plug all holes.strap it to the wheel of your lawn mower. Cut the grass. Tumble clean. It works great for old metal fuel tanks
 Wear your ear muffs !
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeTue Oct 31, 2017 12:06 pm
"Put sand/ gravel in it, your cleaner of choice."
Not too sure about the effect on the level sensor.
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeTue Oct 31, 2017 1:24 pm
level sensor is shot.
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeTue Oct 31, 2017 3:26 pm
Time for a new reservoir.
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeTue Oct 31, 2017 4:15 pm
The brown goo you're seeing might be the original dexcool/stopleak mixture that GM added at the factory 22 years ago. People way more skilled than me have thrown out expensive radiators caked with this stuff because they couldn't find a solvent that could get it off.
Back in the day I used the fine gravel/sand at the end of my driveway and just shook the daylights out of it. It got a lot out but not all. The lawnmower trick is probably more effective. The float switch worked just fine after. Took awhile to get all the rocks out though.
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeTue Oct 31, 2017 5:26 pm
I have muriatic acid in it today I put it in last night and the fluid was brown this morning a lot has come out and I expect more. Tonight I will flush it and install regardless of the outcome.
the car will be stored I n a few weeks so a new reservoir may be added to the list of things I would “LIKE” to do to the car over winter.
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeWed Nov 01, 2017 1:57 pm
Muriatic acid worked well. It also cured the low coolant sensor problem! Smile
I also pulled the Knock sensors before I filled it back up.
I did an oil change while I was under there, but now my service engine light is on.
I cant remember if this vehicle is OBDII or not.
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeWed Nov 01, 2017 2:49 pm
OBD1
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeWed Nov 01, 2017 3:08 pm
silverfox103 wrote:
OBD1
Is the plug the same? can you kill the light with an OBDII reader?
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeWed Nov 01, 2017 8:01 pm
""Is the plug the same?""
No.
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeThu Nov 02, 2017 6:17 pm
FWIW after all this and putting $25 worth of antifreeze in it, I now have a coolant leak that appears to be coming from the waterpump area.
I will be parking the vehicle early for the season and fixing it later.
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeThu Nov 02, 2017 8:03 pm
But the good news is, you have a clean tank!
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeFri Nov 03, 2017 2:16 am
""coolant leak that appears to be coming from the waterpump area.""
Check the pump attaching bolt tightness before doing anything else.
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeFri Nov 03, 2017 2:52 am
Now that you mention it Rev Bob, doesn't one of those bolts have to be sealed?
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeFri Nov 03, 2017 3:42 am
Yep. Lower bolt (retains fan pulley bracket if towpack), passenger side should have thread sealant.
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeFri Nov 03, 2017 1:13 pm
My guess is that after 23 years, 162K miles, and all the harsh chemicals I have put in trying to “clean out” the system, something has to give. When I have time and space to put it on the hoist I will do my best to determine the cause, but likely I will be replacing the WP all hoses and belts ETC.
it would have been parked at the end of the month regardless due to the snow.
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeFri Nov 03, 2017 3:09 pm
Too bad no before and after tank pics?
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeFri Nov 03, 2017 6:18 pm
To be honest nothing was cleaned on the outside and I doubt the translucency was improved much. But it is nice to see less brown inside.
kidder482
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeTue Oct 23, 2018 1:57 am
I have HEARD, that putting a bunch of ground coffee in a crummy coolant tank with some water will clean them well.
It also kind of makes Cold Brew, but I wouldn't try it. I heard about this from the SAAB 9000 community back in the day.
frederickflintstone
frederickflintstone
PostSubject: Re: filthy coolant reservoir tank   filthy coolant reservoir tank Icon_minitimeTue Oct 23, 2018 4:20 pm
FWIW I didn't even put a battery in it this summer. I have been driving my corvette and have not wanted to spend the money for insurance and a waterpump to drive the wagon. I need to look into collector car insurance as most all of my vehicles have suffered from lack of use.
