 What's holding that chime module in place???
PostSubject: What's holding that chime module in place???   Sun Dec 10, 2017 5:55 pm
OK, the chime module in my Caprice wagon is simply not going to budge by simply pulling it straight back, but I can neither see nor feel a clip or catch that's holding it in place.  What's the secret?
PostSubject: Re: What's holding that chime module in place???   Sun Dec 10, 2017 7:02 pm
According to the FSM, there should be a large plastic clip in the center behind the module. To remove the inconvenient center, there are two 7mm head screws, one behind the module, and the other in the hole at the front of the module, between the flasher relays. You should be able to turn the inconvenient center to expose it once it is loose.
PostSubject: Re: What's holding that chime module in place???   Sun Dec 10, 2017 8:02 pm
Once you remove that, you can install your pedals for your T56 swap! You're almost there!
PostSubject: Re: What's holding that chime module in place???   Sun Dec 10, 2017 8:07 pm
Quote :
Umm... you're writing to the guy who can't remove the chime box.
PostSubject: Re: What's holding that chime module in place???   Mon Dec 11, 2017 12:53 pm
It's good to set goals, lol
PostSubject: Re: What's holding that chime module in place???   Mon Dec 11, 2017 4:20 pm
^ Agreed. Haha
PostSubject: Re: What's holding that chime module in place???   Sun Dec 17, 2017 5:49 am
Couldn't seem to get hold of the upper 7mm head screw, and so blundered onto an easier solution: push a narrow (1" wide) plastic scraper blade across the center top edge of the chime box straight towards the firewall, and it will lift edge of the retaining clip enough to pull the chime box to the rear and out.
Monkey discovers tool use!
PostSubject: Re: What's holding that chime module in place???   Sun Dec 17, 2017 9:58 am
RedandBlack wrote:
^ Agreed. Haha
18436,....
PostSubject: Re: What's holding that chime module in place???   Sun Dec 17, 2017 1:07 pm
if you have an aftermarket tune with vats disabled, may as well remove the TDM while you're in there.
PostSubject: Re: What's holding that chime module in place???   Sun Dec 17, 2017 9:21 pm
Quote :
One demon at a time. That one is presently causing no trouble. I'm inclined to leave it alone rather than attract its attention.
PostSubject: Re: What's holding that chime module in place???   Sun Dec 17, 2017 10:22 pm
What year is your car?
PostSubject: Re: What's holding that chime module in place???   Mon Dec 18, 2017 4:37 am
1996
See:  http://gmlongroof.4umer.com/t12235-december-2015-wagon-of-the-month-dmg4-1996-rolling-cathouse-caprice?highlight=cathouse
» I am Neno from Neno"s Place
» Need Dairy Free Milk in Katy, TX (Houston)
» frozen milk to donate - Iowa City
» The place 2B (BIGSIS' bed&breakfast)
» Jane Tanner Statement 4th May 2007
