 water pump on LT1
frederickflintstone
frederickflintstone
water pump on LT1 Empty
PostSubject: water pump on LT1   water pump on LT1 Icon_minitimeWed Mar 07, 2018 12:53 pm
last fall I went on aggressive flushing campaign in order to get the heat working better. in the process I developed a leak dead center in the front of the engine. I assume it is the water pump. How difficult is it to replace the water pump on the LT1? does the opti-spark have to come out?
any tips or tricks?
PostSubject: Re: water pump on LT1   water pump on LT1 Icon_minitimeWed Mar 07, 2018 1:28 pm
I'd check the hose connections at the pump first for drips, unless you see coolant leaking from the gasket or shaft.
It's not difficult to replace the pump, and it's not necessary to touch the Optispark in the process. Even I did it without a screw up.
Does yours have the clutch driven metal fan or electric fans?
frederickflintstone
frederickflintstone
PostSubject: Re: water pump on LT1   water pump on LT1 Icon_minitimeWed Mar 07, 2018 2:04 pm
I believe it has both fans, I know it has the engine driven fan. pretty sure it is not a hose, but of course I will check before i order parts.
I am glad I dont have to remove the opti-spark.
I will check it out more when the weather warms up.
PostSubject: Re: water pump on LT1   water pump on LT1 Icon_minitimeWed Mar 07, 2018 7:59 pm
It's pretty easy. If your Opti cap and rotor has NOT been replaced, 145K would be a good time to do it. just the cap and rotor. It's right there once the water pump is off.... just saying
frederickflintstone
frederickflintstone
PostSubject: Re: water pump on LT1   water pump on LT1 Icon_minitimeThu Mar 08, 2018 9:37 am
thanks, I cant remember if I did that or not.
PostSubject: Re: water pump on LT1   water pump on LT1 Icon_minitimeThu Mar 08, 2018 9:50 am
Let sleeping dogs lie,.. i'm just saying
PostSubject: Re: water pump on LT1   water pump on LT1 Icon_minitimeSun Mar 11, 2018 2:51 pm
I'm pretty sure you'd remember if you did.
if you do pull the WP, make sure you replace the seal.
frederickflintstone
frederickflintstone
PostSubject: Re: water pump on LT1   water pump on LT1 Icon_minitimeMon Mar 12, 2018 8:12 am
what seal are you speaking of?
PostSubject: Re: water pump on LT1   water pump on LT1 Icon_minitimeMon Mar 12, 2018 4:44 pm
waterpump and optispark seal. Found in Felpro timing cover gasket kit.
homemade tool to install seal
you can watch this video to see how it's done: http//www.impalassforum.com/vBulletin/34-engine-problems-maintenance/250397-96-impala-camshaft-optispark-seals-replace-video-3.html
water pump on LT1
