 Air pump delete/header questions
BigBrian
Air pump delete/header questions Empty
PostSubject: Air pump delete/header questions   Air pump delete/header questions Icon_minitimeTue Mar 13, 2018 8:56 am
Good morning!
I have a 1992 RMW with the 350 TBI. I have a couple of questions.
Will deleting the air pump and lines improve hp or fuel economy?
If I do delete the air pump, can I run headers? If so, what fits this car? Will I lose my EGR with headers?
Thanks!
PostSubject: Re: Air pump delete/header questions   Air pump delete/header questions Icon_minitimeTue Mar 13, 2018 9:59 am
""Will deleting the air pump and lines improve hp or fuel economy?""
No. The air pump setup allows the 3 way cat convertor to come up to temperature quickly under cold rich conditions, when unburned hydrocarbons are high. The magical reduction of pollutant products in the cat only occurs at very high honeycomb temperatures.
If your local laws permit it, removing the cat will make more improvement than headers.
BigBrian
PostSubject: Re: Air pump delete/header questions   Air pump delete/header questions Icon_minitimeTue Mar 13, 2018 11:19 am
Good to know.
Since this car is a pre-obd2 I can remove the cats without issue.
Thank you.
PostSubject: Re: Air pump delete/header questions   Air pump delete/header questions Icon_minitimeTue Mar 13, 2018 12:21 pm
You can still run headers and keep EGR. I had a set of Hedman shorties on my car back when it was TBI powered, no AIR pump, and a functional EGR valve.
There's a different belt routing you have to make when the AIR pump is removed, and a different length. From memory (it's been a few years) I ran a 95.5" belt, so 5060955 at the part store.
BigBrian
PostSubject: Re: Air pump delete/header questions   Air pump delete/header questions Icon_minitimeTue Mar 13, 2018 5:05 pm
Awesome! Just what I was hoping to hear!
I read about the belt rerouting and size difference so I'm good there.
Thank you
BigBrian
Thank you
PostSubject: Re: Air pump delete/header questions   Air pump delete/header questions Icon_minitimeTue Mar 13, 2018 5:37 pm
A good place for TBI info is www.thirdgen.org
BigBrian
PostSubject: Re: Air pump delete/header questions   Air pump delete/header questions Icon_minitimeTue Mar 13, 2018 6:14 pm
Thanks!
PostSubject: Re: Air pump delete/header questions   Air pump delete/header questions Icon_minitimeSun Mar 25, 2018 9:52 am
Either 95 or 96 inch belt will work. I used the 95 successfully. As mentioned it doess require a different routing path.
I had pictures, but refuse to pay photobucket keeping my pictures hostage.
