 '89 Le Sabre door lock switch?
redcaddy
redcaddy
'89 Le Sabre door lock switch? Empty
PostSubject: '89 Le Sabre door lock switch?   '89 Le Sabre door lock switch? Icon_minitimeMon Jun 04, 2018 11:15 am
The auto door locks were intermittent, when I reached the proper level of frustration, I took the bull by the horns and did the troubleshoot dance. pulled the door panel off and checked all the wiring.
At the end of a very frustrating day, I discovered some corrosion on the brass strips molded to the back of the switch. The corrosion had eaten away most of the little brass strip. I thought this would be an easy fix. (find and plug in a new switch) Silly me, I discovered that the only switches available had 3 prongs arranged diagonally, The one in my '89 has 3 prongs in an L shape configuration.
Long trip to all 3 of my local "pic N' pull" yards, no joy. Everything pre 2000 has been crushed. All the '90 and later bodies I have looked at have a very different style of switch, not adaptable.
I went looking for a 3 diagonal plug I could splice into the door, apparently, no body can/will sell me this plug new and I can't find one used.
Can anybody help me out with a good, useable original switch or a diagonal 3 switch and plug (fits the same hole in the door panel)
As usual, have money, need parts...
Thanks, Paul in Venice
redcaddy
redcaddy
PostSubject: Re: '89 Le Sabre door lock switch?   '89 Le Sabre door lock switch? Icon_minitimeFri Jun 08, 2018 9:06 pm
bumpity bump bump. Tap, Tap, Tap is this thing on?
PostSubject: Re: '89 Le Sabre door lock switch?   '89 Le Sabre door lock switch? Icon_minitimeFri Jun 08, 2018 10:14 pm
If you are needing a part you will have better luck finding it by asking in the right section.
https://gmlongroof.4umer.com/f9-wanted
redcaddy
redcaddy
PostSubject: Re: '89 Le Sabre door lock switch?   '89 Le Sabre door lock switch? Icon_minitimeSat Jun 09, 2018 12:07 pm
Sorry, I guess I expected some trouble shoot help or insight from the electrical section.
Do I repost (cut n' paste) in the wanted section or can/would a moderator move it for me? On second thought, I suppose it's likely more fiting in the "boxie's forum.
Thanks
PostSubject: Re: '89 Le Sabre door lock switch?   '89 Le Sabre door lock switch? Icon_minitimeSat Jun 09, 2018 12:57 pm
Cut off old connector. Put new individual terminals on wires. Connect.
redcaddy
redcaddy
PostSubject: Re: '89 Le Sabre door lock switch?   '89 Le Sabre door lock switch? Icon_minitimeSat Jun 16, 2018 7:39 pm
Thanks Jay, I'll work that plan, as soon as I find a new switch. ( of either configuration )
Thanks, Paul
PostSubject: Re: '89 Le Sabre door lock switch?   '89 Le Sabre door lock switch? Icon_minitimeSat Jun 16, 2018 8:03 pm
Post a pic of the switch you need, please.
redcaddy
redcaddy
PostSubject: Re: '89 Le Sabre door lock switch?   '89 Le Sabre door lock switch? Icon_minitimeThu Jun 28, 2018 2:30 pm
Just to close out this thread. I couldn't get my phone pic's to post, GRRRRR.
What I did was to solder a piece of 22 gage wire across the missing spot. The plastic was more heat resistant than I expected. 15 watt iron and some micro soldering skill. Viola, the original switch marches on..
Thanks for the offered help Cool
Paul in Venice
» Door Lock Switch for Driver door
» Roadmaster door lock switch illumination?
» 1996 Roadmaster drivers door lock/unlock switch, no longer needed
» Remote lock drivers door lock problems
» Dual batteries in a '89 Buick Le Sabre Estate Wagon, boxie ?
