 1996 Roadmaster engine will not crank.
Jimosborn
Jimosborn
1996 Roadmaster engine will not crank. Empty
PostSubject: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeSun Mar 03, 2019 6:45 pm
My 96 will not crank. Battery is 3 months old and is at 12.6 volts cold. When jumping it is at 14v. Turning the key all the lights in dash turn on but there is no cranking. Both keys same issue. All fuses are good. It started no problem this morning, but on this afternoon.
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeSun Mar 03, 2019 7:39 pm
I had pretty much the same thing happen with my car a few months back. Started fine in the morning but when I tried to go home after work it wouldn't crank but everything else came on.
Ended up being the starter had gone out.
Jimosborn
Jimosborn
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeSun Mar 03, 2019 10:43 pm
The passkey light is flashing. What is the easiest way to fix an issue with the passkey system.
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeSun Mar 03, 2019 11:59 pm
Cut a resistor into the wiring at base of steering colum. Google has step by step instructions.
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeMon Mar 04, 2019 12:00 am
But Vats the car will still crank so that’s not it
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeMon Mar 04, 2019 5:41 am
Do the lights dim when you turn the key to the "start" position? Check starter and solenoid? Does someone listening under the hood hear a "click" when the key is turned to "start"? Did you clean the battery connections? Bad connections or a bad starter (or both) would commonly produced the symptoms you describe, and if you are lucky it's one of these easily traced issues.
Tapping the side of a starter that's on the way out with a hammer is a tried and true shade-tree mechanic technique that often persuades the starter that you really mean it this time and that your patience is wearing thin.
Actually it can loosen crud and carbon internally and gets it to kick over one more time, although it is on borrowed time.
Isurf
Isurf
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeWed Mar 06, 2019 4:05 am
My starter failed recently. The local shop dropped in a replacement, that is already showing signs of trouble. Read the comments about alternate starters in that thread: [You must be registered and logged in to see this link.]
Jimosborn
Jimosborn
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeSat Mar 30, 2019 2:58 pm
Replaced starter and still no cranking.
Jimosborn
Jimosborn
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeSat Mar 30, 2019 3:06 pm
Replaced starter and still no cranking. I head a click under the hood. Going to replace the cable from starter to battery.
Jimosborn
Jimosborn
PostSubject: Re: 1996 Roadmaster engine will not crank.   1996 Roadmaster engine will not crank. Icon_minitimeMon Jun 10, 2019 10:17 pm
Finally figured it out. There was a third party antitheft device with a printed circuit card like key. It had a relay that was spliced into the main yellow ignition wire and the socket for the key card was stuff way up under the dash. I cut it out and reconnected the wires it bypassed. It strated right away.
