 Transmission swap for towing
rallysanti
Transmission swap for towing Empty
PostSubject: Transmission swap for towing   Transmission swap for towing Icon_minitimeWed Mar 13, 2019 9:15 am
Hi everyone, looking for advice. I've been using my 95 wagon to tow my race car around for the last year and a half. Coming back from my last race, it started slipping going uphill. I want to swap in something stronger.
Going back and forth on my options.
4L80 - affordable, should bolt up with repinned or reprogrammed ECM. Need deeper rear end gear. Late 90's/early 2000s 2wd van seems like a good swap candidate
T56 - should bolt up, common enough swap. Will definitely need gears (4.3+). Harder to find, but more fun
NV3500 - Truck transmission, shouldn't sweat towing. Less information available, probably look to dodge trucks for the wide ratios
Appreciate any input.
Thanks
Transmission swap for towing 20545260_2124342684462739_8949511111817096222_o.jpg?_nc_cat=106&_nc_ht=scontent-dfw5-1
http://instagram.com/escuderiaboricua/
PostSubject: Re: Transmission swap for towing   Transmission swap for towing Icon_minitimeThu Mar 14, 2019 10:18 am
Did you post on the facebook group a few days ago with this exact question? If so I'll skip reposting my response.
» transmission swap
» Towing without the tow package
» towing with t56
» Bent tie rod from towing?
» Towing Advice
