 fuel tank...
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: fuel tank...   fuel tank... Icon_minitimeWed Mar 13, 2019 5:21 pm
Thanks to tons of great info here and on the SS forum for fuel tank removal the job wan't too bad... Did it by myself in an hour or so. I wish the pump wasn't dead so I could have used the jumper wire to drain the tank. The old gas smells terrible! I would guess there
I already have a new sending unit and fuel pump to go back in but possibly ran into a bigger issue with the tank itself.
There is a small split in the plastic on the top of the tank, right in the curve where the tank hits the car frame. It seems to be an odd place for the plastic to crack... I see that a new tank isn't available, so it's either try and seal the tank or find a decent used one. The crack is maybe two inches long.
here are a couple pics:
Fuel slosh showed the crack:
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 13, 2019 6:40 pm
Here a some more pics:
crack is on the bottom left of this pic where the indent is for the car body.
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 13, 2019 7:55 pm
Where are you located?
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 13, 2019 8:18 pm
I've had two that were cracked on the top like that. Until I was able to get a replacement, I just filled to 3/4. I dunno if plasti-weld type stuff will work or not. If you are on the eastern seaboard somewhere I think 94Woody may be able to help you out Smile
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 13, 2019 8:51 pm
I'm in Raleigh, NC... I will update my profile.
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 13, 2019 10:27 pm
To use the plastic weld you need a stick of the same type plastic as the tank. It may work fine, if you continue the "weld" past the ends of the crack. Plastic welding requires a lot of heat, and an empty tank, or one filled with water to near the top is advised.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeThu Mar 14, 2019 7:14 pm
I posted above and updated my profile...
I just looked to see where your located, we were just in Ocala a couple weeks ago for a car show!
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeThu Mar 14, 2019 9:00 pm
Cool, myself and Sprocket were at that show as well.
Florida Wagonfest is next weekend at Daytona.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeThu Mar 14, 2019 9:14 pm
Cool!
We didn't have anything in the show this year, but my wife was judging. I helped a friend by driving in his 1929 Model A Ford coupe while he drove his '29 Model A Rodester, that was fun!
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeSat Mar 16, 2019 3:52 pm
I pulled the old sending unit/pump assembly today. I also drained as much of the nasty old fuel as I could, quite horrific stuff!
Is there a decent way to clean the inside of the tank of the remaining fuel and gunk that's in there? I would guess that there is still a half gallon or so of gas in there...
I also picked up the cheap [You must be registered and logged in to see this link.] from Harbor Freight.
I was going to post up some pics but Imgur is fighting me right now... I'll try again later.
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeSat Mar 16, 2019 7:48 pm
You can put your own pictures on here from your computer.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeSun Mar 17, 2019 10:59 am
here are some pics of the nastiness...
new and old:
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 20, 2019 1:30 pm
you might want to post in the Wagonfest FL threads to see if someone would give 94 Woody's gas tank a ride up to NC from Daytona and just meet them at an exit off of I95. Pretty sure at least one of them would be willing....just trying to help out.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 20, 2019 4:43 pm
I like that idea!
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 27, 2019 7:20 pm
So I used some [You must be registered and logged in to see this link.] in the tank to help clean out the remaining gunk. It seemed to cut through the stuff decently. I also reached in a wiped what I could with a rag. Then I rigged up a [You must be registered and logged in to see this link.] and some extra tubing to extract the remaining stuff that was in there. I left it sitting for a couple days to air out some more.
Today I used the plastic welder I got from Harbor Freight. First I cleaned the area with carb cleaner spray. Then I sanded the area a bit to clean it more and scuff up the area. Then I went to work with the welder, seemed to OK! I ran the tip of it through the crack to try and seal it up, then I added some plastic to the area and spent some time melting that into the tank and smoothing the area. It seems to have patched the area and hopefully it holds up  long term.
Here are some pics, sorry didn't get any action shots as I was working alone.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 27, 2019 7:28 pm
I have a question about the new sending unit I got. I has release tabs on it like the fuel filter, should I leave them on there? The old unit didn't have them...
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeWed Mar 27, 2019 7:41 pm
You can remove them if they are not used.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeSun Apr 07, 2019 9:53 pm
Spent some time today working on the car. Picked up a new piece of fuel line to replace the disintegrated vent hose. I started putting the tank back in and found that the new Dorman fuel filler neck is not bent and shaped the right way to fit! So out that came and I put the original back in. Not thrilled with that as there is some surface rust inside the filler neck. I ran out of time and couldn't finish up everything. The straps are fighting me a bit...
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeSun Apr 07, 2019 10:17 pm
That cross strap can be a pain in the butt. I raise the tank into place and put some jack stands under it so it hangs down a little. Put the bolts through the front and lift them into place and turn in the the rear bolts a turn or two. That allows the cross strap to easily slide over the stud in the front.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeMon Apr 08, 2019 7:54 am
Thanks for the tips 94Woody.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeMon Apr 08, 2019 5:35 pm
Earlier today I managed to get the cross strap in place and tightened all the strap bolts. I routed and connected the wiring. I also got the filler neck and vent tube hoses clamped in place. I connected the tank vent line and reconnected the strap on the body to hold the three lines in place.
Hopefully I won't have to touch this again for a long time. Smile
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeMon Apr 08, 2019 6:47 pm
Hopefully not. I dropped mine 3 times before I got it right.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeMon Jun 03, 2019 8:06 pm
looks like I have to drop the tank again! Mad Filled it up the other day after getting work done at the shop. There is a decent fuel leak from somewhere up top! Mad Can't see anything yet except fuel running down the front of the tank, maybe from the sending unit?!
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeTue Jun 04, 2019 3:33 pm
pics from last night
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeTue Jun 04, 2019 10:45 pm
It could be your vent hose. It is 18mm hose. There are other possibilities, but check the hose.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeThu Jun 20, 2019 5:08 pm
Looks like my repair was a failure! Sad
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeMon Jun 24, 2019 4:04 pm
She found a guy parting a '96 Roadmaster wagon, so today I went over there and pulled the tank from it. Looks to be in good condition, have to clean it up, drain the old gas from it and swap over the pump/sending unit.
RadioFlyer
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeTue Jun 25, 2019 3:06 pm
I hope the new one works out for you. Going to be dropping the tank on mine in the not too distant future.
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeTue Jun 25, 2019 3:08 pm
Nice. That's basically the only way to get a tank for one of these cars. Hope it works for you.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeTue Jun 25, 2019 4:47 pm
Thanks guys.
I cleaned the outside of the tank yesterday and it looks to be in great condition!
The car it came out of has 250,000+ miles on it. The car is still in pretty decent condition, but has a bad engine and the passenger side back window is broken so the interior is getting a bit trashed. It is tan on tan.
rcktpwrd
rcktpwrd
fuel tank... Empty
PostSubject: Re: fuel tank...   fuel tank... Icon_minitimeSun Jun 30, 2019 5:23 pm
Got the 'new' tank installed and the car running, all seems well now! Very Happy
fuel tank... Empty
fuel tank...
» WW2 RAC TANK HELMET
