 TBI Coolant Level Sensor help
r67northern
r67northern
TBI Coolant Level Sensor help Empty
PostSubject: TBI Coolant Level Sensor help   TBI Coolant Level Sensor help Icon_minitimeMon Jul 29, 2019 1:08 pm
Hi All,
In the midst of doing a radiator replace, I separated the threads on the little coolant level sensor that sits in the radiator for these TBI engines. Seems like it's a part that can't be had anymore...
It looks like it's just a simple little part, basically a strip of metal surrounded by plastic (brittle) threads. Any advice on this? I'm considering "faking out" the system by adding a resistor to the sensor wire and perhaps grounding it out if I get the right resistivity off the broken sensor. I guess I could pull the dashboard Low Coolant light out too...
Any input appreciated. Thanks!
PostSubject: Re: TBI Coolant Level Sensor help   TBI Coolant Level Sensor help Icon_minitimeMon Jul 29, 2019 10:05 pm
The last time I saw one was about 2 years ago, and it was about $35. I have a good used one for $35 shipped. LMK. Use antiseize when installing.
r67northern
r67northern
PostSubject: Re: TBI Coolant Level Sensor help   TBI Coolant Level Sensor help Icon_minitimeTue Jul 30, 2019 12:14 pm
Thanks Fred, I may be following up with you shortly on this. I’m taking a quick stab at adapting something that is still currently manufactured just for fun.
r67northern
r67northern
PostSubject: Re: TBI Coolant Level Sensor help   TBI Coolant Level Sensor help Icon_minitimeSun Aug 04, 2019 8:01 pm
Hi Everyone,
I can report that this alternate sensor:
Standard Motor Products FLS3 Coolant Level Sensor [You must be registered and logged in to see this link.]
will work! Amazon (link above) sells these for about $6. It will screw in no problem and seal. The connector is a different design so you’ll have to adapt the original sensor wire to the new sensor. I did this with a spade connector into the original sensor wire, then jimmied up a female spade connector to fit over the new sensor. Works like a charm.
PostSubject: Re: TBI Coolant Level Sensor help   TBI Coolant Level Sensor help Icon_minitimeSun Aug 04, 2019 8:14 pm
Good, now I will not have to hoard the OEM ones.
» Low coolant level sensor
» 96 RMW coolant level sensor?!!
» Low coolant level sensor switch
» Oil Level Sensor
» Oil level sensor p/n
