 Adapter to replace power antenna
Walterf
Adapter to replace power antenna Empty
PostSubject: Adapter to replace power antenna   Adapter to replace power antenna Icon_minitimeTue Nov 12, 2019 9:44 am
1991 OCC with (surprise!) broken power antenna. All replacement antennas, whether power or fixed mast, do not adapt to the existing antenna lead wire. Replacing to the lead cable involves not only radio removal but disassembly of dash board.
If you need to replace your antenna but want to leave existing lead cable, Metra 40-GM18 adapter is the way to go. One end accepts a typical antenna lead wire and the other has a female spring loaded Motorola end. The part is not well known but can be found online by searching for the part number. It can be listed as Metra or Antennaworks.
PostSubject: Re: Adapter to replace power antenna   Adapter to replace power antenna Icon_minitimeTue Nov 12, 2019 8:57 pm
I have a repairable OEM antenna. It has a good mast. The mast is the impossible part to find. I bought the last new one that was available, and used it. You can find a good motor in almost any power antenna around the same era, and the cables are still available from antennasareus.com.
Aftermarket head units usually require a patch cable as well.
