| Glove Box Help- 95 RMW | |
+5Olds Weighty Eight jimbeau Fred Kiehl jayoldschool SCbarber 9 posters |
SCbarber
Posts : 113 Join date : 2009-12-20 Age : 50 Location : Lexington, SC
| Subject: Glove Box Help- 95 RMW Sun Mar 25, 2012 3:57 pm | |
| My glove box will not close, replaced lock and it still does not close anyone have this issue and how did you get it to stay shut? There is nothing in the way, it just does not stay closed. | |
| Subject: Re: Glove Box Help- 95 RMW Sun Mar 25, 2012 4:16 pm | |
| Have you made sure there is nothing blocking the guide arms way?Could be something behind the box blocking the arms pathway! |
SCbarber
| Subject: Re: Glove Box Help- 95 RMW Sun Mar 25, 2012 4:20 pm | |
| Just as I stated above, there is nothing in the way..lol it is really annoying me not being able to close my glove box, but I guess thats a minor thing..LOL | |
| Subject: Re: Glove Box Help- 95 RMW Sun Mar 25, 2012 4:43 pm | |
| Loosen the little screws that hold the latch, and move it out a little. | |
| Subject: Re: Glove Box Help- 95 RMW Sun Mar 25, 2012 8:46 pm | |
| The striker may be bent. It is nearly impossible to replace the striker without tearing out the whole dash. It is made of sheet metal, so it is easy to bend. | |
| Subject: Re: Glove Box Help- 95 RMW Sun Mar 25, 2012 9:18 pm | |
| - Fred Kiehl wrote:
- The striker may be bent. It is nearly impossible to replace the striker without tearing out the whole dash. It is made of sheet metal, so it is easy to bend.
Well, you didn't say, but can't he just 'bend' it back a little rather than tearing out the whole dash? | |
SCbarber
| Subject: Re: Glove Box Help- 95 RMW Sun Mar 25, 2012 9:26 pm | |
| I had a loose connection in my module? (was causing engine light to come on) and I think it got repaired through the right side of dash near glove box where that panel comes off. I am not sure but it worked fine prior to this being done. | |
| Subject: Re: Glove Box Help- 95 RMW Sun Mar 25, 2012 10:17 pm | |
I stated it was easy to bend, so by inferrence, it can be bent back as easily as it is to bend. | |
| Subject: Re: Glove Box Help- 95 RMW Sun Mar 25, 2012 10:21 pm | |
| Subject: Re: Glove Box Help- 95 RMW Mon Mar 26, 2012 1:28 pm | |
| Greg,thats just mean
and FUNNY too! |
SCbarber
| Subject: Re: Glove Box Help- 95 RMW Mon Mar 26, 2012 1:32 pm | |
| May just do that (from the inside) Thanks for the help, I greatly appreciated the correct way to fix the glovebox..LOL | |
SCbarber
| Subject: Re: Glove Box Help- 95 RMW Sun Apr 01, 2012 9:18 pm | |
| Yep, still got that open glove box..LOL | |
brokecello Moderator
| Subject: Re: Glove Box Help- 95 RMW Sun Apr 01, 2012 9:44 pm | |
| Can you take a pic of the latch and the striker? Will it not close all the way? Dont forget those two rubber stoppers (flaps) on the sides. If they were pooped out...that could keep the door from closing. | |
EagleMark
Posts : 6 Join date : 2012-04-15 Age : 63 Location : North Idaho
| Subject: Re: Glove Box Help- 95 RMW Sun Apr 15, 2012 5:01 pm | |
| Is the latch closed? Open it then shut the glovebox... | |
SCbarber
| Subject: Re: Glove Box Help- 95 RMW Sun Apr 15, 2012 5:15 pm | |
| It has been fixed, striker and lock plate out of alignment. Thanks for all the replies. | |
| Subject: Re: Glove Box Help- 95 RMW Sun Apr 15, 2012 10:10 pm | |
| Did it poop out the rubber stoppers? Sorry Chris, couldn't resist | |
| Subject: Re: Glove Box Help- 95 RMW Sun Apr 15, 2012 10:18 pm | |
| get rid of that annoying rattle,. nick | |
| Subject: Re: Glove Box Help- 95 RMW Sun Apr 15, 2012 11:55 pm | |
| Subject: Re: Glove Box Help- 95 RMW | |
