| 4.11 rear and new rear brakes - DONE!! | |
+4toomanytoyz jayoldschool 81X11 BigBlackBeaSSt 8 posters |
| Subject: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 7:58 am | |
| BEFORE: (100,000 miles of daily grind on the rear brakes) REAR: Started life as 2.56 then 3.08 (just because), then 3.73 (as an automatic they were wonderful), now 4.10/4.11 works better for towing with t56. Took my time and painted everything up and replaced the wheel cylinders. Hope it goes another 100k. | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 8:36 am | |
| The way you take care of this wagon,2 hundred thousand is going to be a definite YES! |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 8:37 am | |
| 230+ now so another 100 should give me 330+... | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 11:02 am | |
| Watch for leaping sheds.
Looks nice. I bet those gears make that a REALLY fun car. |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 11:16 am | |
| Yeah, I think the sheds are in rut. I almost had one jump in front of me last night or was that a deer..... hmmmm.
YES 4.11 + 355 + T56 = FUN | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 11:23 am | |
| Sweet mod! Where's the RPM sitting at highway speeds now? | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 11:34 am | |
| I have not been on the highway just yet. based on my excel spread sheet it should be at 1779 RPM at 70 MPH. But that seems kind of low. I will report back.
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 3:37 pm | |
| - BigBlackBeaSSt wrote:
- Yeah, I think the sheds are in rut. I almost had one jump in front of me last night or was that a deer..... hmmmm.
YES 4.11 + 355 + T56 = FUN Had 2 doe and 2 much younger deer in my front yard at 4am when I put my girls out.These 2 does must not be in the mood yet because they stay in my yard most all night and sometimes until 10am.Use to them now but they scare my girls.Better in my yard than on the road destroying cars! |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 3:41 pm | |
| So are they 4.10s or 4.11s? | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 4:20 pm | |
| - jayoldschool wrote:
- So are they 4.10s or 4.11s?
Yes | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 5:12 pm | |
| lol, did you miss math class on division day? 41 teeth ring, 10 tooth pinion by any chance? | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 6:41 pm | |
| The manufacturer actually had 4.10/4.11 stamped on the pinion. | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 6:44 pm | |
| - Flasheroo wrote:
Had 2 doe and 2 much younger deer in my front yard at 4am when I put my girls out.These 2 does must not be in the mood yet because they stay in my yard most all night and sometimes until 10am.Use to them now but they scare my girls.Better in my yard than on the road destroying cars! Sat in a tree today from 2:30 ish til dark and never saw one. I the way home I had a buck and two doe in three different places almost cross the road in front of me. | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 7:35 pm | |
| You'll love the gears. Best thing you can do for a T56. Speaking of wildlife in the yard, I had two of these in my backyard yesterday. No, not mine. | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 7:52 pm | |
| Congrats on the gear swap. Now it feels like a stock Impala. 4.56's next. | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 10:22 pm | |
Gear swappers take note - label EVERYthing. | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Mon Nov 05, 2012 10:25 pm | |
| I wrote R & L on my arms. I am little slow... | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Tue Nov 06, 2012 5:54 am | |
| Did you setup the gears yourself? Did you have to change the pinion spacer or the carrier shims? | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Tue Nov 06, 2012 7:36 am | |
| Had to change the carrier shims | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Tue Nov 06, 2012 12:20 pm | |
200OZ Moderator
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Tue Nov 06, 2012 12:32 pm | |
Gear swappers take note - label EVERYthing. I get the bearing caps, shims, and even the bolts, but labeling the axle housing L and R while it's in the car.... OK.... I guess. Seems akin to labeling a dash that's in a car L and R so you know where to sit. Mike | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Tue Nov 06, 2012 1:13 pm | |
| I have labeled the dash AND seats, whats wrong with that? | |
| Subject: Re: 4.11 rear and new rear brakes - DONE!! Wed Nov 07, 2012 5:58 pm | |
| I am now doing 1750 ish RPM @ 60 MPH and I can get into 6th @ about 53 mph (was 63). Much better. Particularly better in parking lots/driveway. Tows much better to. | |
uxwbill
Posts : 319 Join date : 2012-08-01 Age : 41 Location : Illinois
| Subject: Re: 4.11 rear and new rear brakes - DONE!! | |
