| Subject: drivers door panel swap Sun Jan 13, 2013 6:38 am | |
| Will be at the u-pull-it at the corner of 675 and 285 in ATL around lunch today (driving up there for work..) and need to know if ANY other LOWER door panels will work for the 96 RMW? I know that the sedans and wagon panels are the same, but are the lower halves the same across the line? | |
DBeaSSt Admin
Posts : 2572 Join date : 2008-11-04 Age : 53 Location : Front Royal, VA
| Subject: Re: drivers door panel swap Sun Jan 13, 2013 9:13 am | |
| Sadly no. LT1 RMW/S panels are unique to Roadmaster. Now, the front doors are the same so if you wanted to experiment with different panels they will fit.... sorta. I do have a drivers door panel in your color, it's slightly cracked. If you're interested let me know. | |
| Subject: Re: drivers door panel swap Sun Jan 13, 2013 9:52 am | |
| I am interested. Ill call you when i get to atl in a couple of hours, if thats ok with gou.
| Subject: Re: drivers door panel swap | |
