 Sensors - oil Level and Preassure?
s1l1sc
Sensors - oil Level and Preassure? Empty
PostSubject: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeMon Mar 04, 2013 7:06 pm
Both of mine are going bad - Autozone wants $40 each - I am sure there have to be better/cheaper options out there. Does anyone know what interchanges?
Also, what other sensors should I look at while I am doing this?
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeMon Mar 04, 2013 7:24 pm
did you check rockauto?
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeMon Mar 04, 2013 7:31 pm
Thats cheap,when I bought my oil pressure sender from rock auto 3 years ago it was 55 bucks.Is your OP gauge needle pegging to the far side of the gauge and staying there except when stopped in drive?
s1l1sc
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeMon Mar 04, 2013 8:14 pm
it is all over the place. When stopped in drive it drops to the left and the low oil light comes on. While driving it jumps all over the place - i did unplug it and clean it the other day (full of oil). It worked for a couple of days, then went crazy again - makes me think it is leaking inside the sensor and shorting out the contacts.
The low oil light in the ac control has been on forever - it turns off on occasion.
I have enough oil in the engine - have been checking on a regular basis.
I have not checked rock auto yet. Ordered the wrong sensor the last time =(
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeMon Mar 04, 2013 10:30 pm
Pick and pull yards are cheap, and most guarantee the part for 30 days. There is a gasket on the level sender that is not available separately. You have to make your own with silicone sealer.
The oil level sender may have a loose/broken wire in the connector. Mine usually works for a couple of days after an oil change, then the light stays on. I have swapped the sender (and in the 91 and 92, the module). The only thing left in my car that could cause the light to be on is a broken wire.
s1l1sc
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeTue Mar 05, 2013 7:55 pm
Thank you guys. Will take a crack at Rock auto. Yarding is not feasible right now due to work schedule and such.
s1l1sc
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeTue Mar 12, 2013 9:25 pm
Alright, looks like it is fixed. Next up: Tailgate sensor :-)
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeTue Mar 12, 2013 10:05 pm
Tailgate sensor?
s1l1sc
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeTue Mar 12, 2013 10:07 pm
The little black plunger par in the tail gate that turns on the gate ajar light on the dash.
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeTue Mar 12, 2013 10:15 pm
do you need one?
s1l1sc
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeTue Mar 12, 2013 10:39 pm
Yup, need a working one.
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeTue Mar 12, 2013 10:48 pm
I have one.
s1l1sc
PostSubject: Re: Sensors - oil Level and Preassure?   Sensors - oil Level and Preassure? Icon_minitimeTue Mar 12, 2013 11:07 pm
Cool - lemme know how much :-)
» Sub-levels (subform) - how to put the word in front of the sub level links?
» [ONLY TOPIC] Admin Level new user activation not working - all users being automatically activated
» Level Up bar
» Level 200 and what hapend
» Warning level icon
